It is currently Fri May 24, 2013 9:10 pm
 Post subject: Schedualling F@H
PostPosted: Thu Jul 15, 2004 6:05 pm
is there away that i can get F@H to start at a certain time(this part i know i can do) and they have it shut down at a certain time?
 Post subject: Re: Schedualling F@H
PostPosted: Thu Jul 15, 2004 6:23 pm
You can pause it when it's done with its chore. ;]
PostPosted: Thu Jul 15, 2004 6:24 pm
i want it to close and act likes its not there, and i dont want to do it my self, i want to set it and forget it, i want it to run from like midnight to 5 am then again from 8 am to 4PM and just do that cycle automatically
PostPosted: Fri Jul 16, 2004 3:00 am
Super Folder
Super Folder
Why not run 24/7, if I may ask?
PostPosted: Fri Jul 16, 2004 6:21 am
Max [Ph]otographer
Max [Ph]otographer
If you were on Linux, I would suggest creating a script. Although, I have yet to create any scripts so I couldn't tell you how to do it. :roll:
I've got my F@H client running on Slackware as a process. I edited the rc.local file to boot slackware before it even boots the GUI. The neat thing is all I have to do to check on it's progress is open the FAHlog.txt file, and it tells me how it's doing.
Damn hard to kill it though, though I haven't tried yet. I do have quite a lot of work done on the Windows client that I would like to finish using Wine. I would of course have to kill F@H first. :?
Dan O.
PostPosted: Fri Jul 16, 2004 6:44 am
Professional Dork
Professional Dork
This really is the correct answer. FAH will give way to any other process on your system, since it runs at low priority all the time.
I've never had issues with games or anything else being interfered with by FAH.
PostPosted: Fri Jul 16, 2004 9:59 am
Agreed. I'd also like to know what is bugging you about it running. It takes over when it needs too. Instead of it showing "Idle Process" running at 99, you get F@H to make your PC earn it's keep...
I also have never had a problem running it all the time. It drops off nicely when I demand work to be done.
PostPosted: Fri Jul 16, 2004 10:04 am
well its the fact that i want to run it on my dads comp but he doesn't want me to install it so i want to run it while he is asleep and gone at work and close just befpre he gets home from works and when he wakes up in the morning
PostPosted: Fri Jul 16, 2004 10:15 am
Oh! Well then...
You can install this pretty silently. What you could do is use something like reshacker and change the program's flower icon to something like logitech's icon and place a shortcut in the startup folder with a name like "logitech manager". Then, go into properties and don't allow it to show in the taskbar. By those two, the only real way he'll see it is by looking at his processes, where it'll be very noticable.
Other than disguising it, I'm short of ideas. I know how to start it up, but I don't know how to shut it down.
PostPosted: Fri Jul 16, 2004 10:18 am
Super Folder
Super Folder
Agreed. Install it and change the icon/name in the startup folder, then don't allow it to show in the taskbar. Chances are, he won't notice it.
Not that I'm condoning installing this on someone's computer without permission or anything.
PostPosted: Fri Jul 16, 2004 1:10 pm
I have. But then, this was at work.
Those who can't code, write software for healthcare. :(
PostPosted: Fri Jul 16, 2004 1:11 pm
my dads running windows 2000 pro can i still hide the icon?
PostPosted: Mon Jul 19, 2004 2:42 pm
If you haven't caught this thread yet...
http://www.maximumpc.com/forum/viewtopic.php?t=987
