It is currently Thu Mar 05, 2015 7:33 pm
 Post subject: Finish WU then shutdown?
PostPosted: Mon May 12, 2014 10:39 pm
Team Member Top 100
Team Member Top 100
Is there an option to put the PC to sleep after active WUs finish?
As I've said, I will be cutting back to almost nothing soon, but I will put up a WU here and there. Thanks to crwlngkngsnk I know about the "finish" option that will not DL another WU after finishing, thus keeping my bonus as high as possible, and never failing to return a WU. I was still wondering if you could set it to shut down as soon as folding stops.
 Post subject: Re: Finish WU then shutdown?
PostPosted: Tue May 13, 2014 5:51 am
I would have liked that option in the client itself but never found it. On linux, I just estimate the time left and set the shutdown timer. Maybe there is a similar MSDOS option or a program for that.
PostPosted: Tue May 13, 2014 7:02 am
Million Club
Million Club
In the older versions, you go into a DOS prompt and configure the client with a flag for -onewu (or something like that).
PostPosted: Tue May 13, 2014 5:01 pm
Million Club
Million Club
I did a little research for your answer....and it's really simple.
Open FAHControl, click on the "Finish" button and viola....done and done.
It will continue the current WU, send the results and terminate.
Sometimes the simpliest things are the toughest to figure out :mrgreen:
PostPosted: Tue May 13, 2014 8:37 pm
Team Member Top 100
Team Member Top 100
This causes the folding to stop, but it doesn't make the PC shut down. I want my PC off when its done so I'm not using all that power at idle.
PostPosted: Tue May 13, 2014 8:38 pm
Team Member Top 100
Team Member Top 100
That was my 1st post with the 250 badge! I think I'm way too exited about that...
PostPosted: Wed May 14, 2014 5:16 am
Like I said, for Windows, your best bet would be to find a program that can be used to set a timer for sleep or shutdown. F@H doesn't have this option. Make sure you also take into account upload times after WU completion when you manually set up a timer.
It's a shame that this option isn't found in many other programs either. I think the last time I saw this ability was either in a disk defragmenter or in a BT-client many years ago.
PostPosted: Wed May 14, 2014 10:56 pm
Team Member Top 100
Team Member Top 100
Yea, I could time it out, I but you gotta have extra on there in case it slows any. I just was wondering if there was an auto function.
I wonder though if anyone makes software that can detect CPU usage an shutdown/sleep after X mins of inactivity.
PostPosted: Thu May 15, 2014 2:22 am
Team Member Top 250
Team Member Top 250
See if this does it.
PostPosted: Thu May 15, 2014 5:13 am
That looks like a promising program. Lots of other nifty-looking programs on their site also.
PostPosted: Thu May 15, 2014 5:06 pm
Team Member Top 250
Team Member Top 250
I haven't personally used any of them, but it looked like a decent find.
PostPosted: Sat May 17, 2014 6:36 pm
Team Member Top 100
Team Member Top 100
Use the Windows Task Scheduler. It will be easier for me to just link you to a guide.
http://www.sevenforums.com/tutorials/95 ... -task.html
PostPosted: Sat May 17, 2014 8:36 pm
Team Member Top 250
Team Member Top 250
Task Scheduler was my first thought, but I couldn't figure out how to trigger a task based on processor use. I'm pretty sure the definition of "idle" is no user input. You could do it by time, but then you have to re-create the task every time. Maybe R3D could let us know what he has tried, if anything, and what kind of results he got. *ahem*
PostPosted: Sun May 18, 2014 7:07 am
Million Club
Million Club
R3D can't answer right now because he successfully shut down the pc after his current WU and now has no connection MaxPC Forums 8)
PostPosted: Sun May 18, 2014 7:56 am
Team Member Top 100
Team Member Top 100
haha, i've always got a connection, ill usually see things on my cell, and reply later at my pc.
Its not that big of a deal, I know there are ways somehow to get it done, but I was curious if it was in the client. I have no real interest in other apps for now, trying to keep the PC clean of extra/rarely used things.
PostPosted: Sun May 18, 2014 8:42 am
Team Member Top 250
Team Member Top 250
That's crazy talk.
