It is currently Wed Mar 04, 2015 12:37 am
 Post subject: Are you using an AMD GPU?
PostPosted: Fri May 02, 2014 8:55 am
Team Member Top 250
Team Member Top 250
So, I was snooping over at bit-tech. They've got a guy with like 6M+ 24 hour average. :shock:
Anyways, I read a post from a guy over there, he says he uses the -beta flag with his AMD card because that way he only gets Core_17 WUs. Apparently the 15s don't Fold as well (aside from being worth fewer points generally) and consequently there is a serious points drop.
I'm not advocating that anyone here stoop to such measures. :wink:
 Post subject: Re: Are you using an AMD GPU?
PostPosted: Fri May 02, 2014 10:08 am
Team Member Top 100
Team Member Top 100
I've gotten core 17 only since I restarted a few months ago, no flags.
PostPosted: Fri May 02, 2014 10:44 am
Team Member Top 250
Team Member Top 250
Hey, I use crappy old NVIDIA cards, what do I know?
PostPosted: Fri May 02, 2014 11:22 am
Team Member Top 100
Team Member Top 100
Are you using the latest folding client? If not you might want to update you client, see if you get better WU's.
PostPosted: Fri May 02, 2014 11:44 am
Team Member Top 250
Team Member Top 250
Who, me? One of my machines is running the latest client, the other is using the older iteration of the new client, so fairly up-to-date, besides, it only SMP Folds. I wonder if anybody has seen any PPD differences between the two.
PostPosted: Fri May 02, 2014 11:48 am
Team Member Top 100
Team Member Top 100
I dont know on that one. I have been away from folding for a while, so I am still getting use to using version 7 and not using version 6.
PostPosted: Fri May 02, 2014 1:54 pm
Team Member Top 250
Team Member Top 250
I tried installing V6 when I was having some problems (I wanted to eliminate Core_17 WUs), it wouldn't install for some reason and I didn't really pursue it.
