It is currently Wed Apr 01, 2015 8:36 am
 Post subject: Core 17 not using CPU (slow)
PostPosted: Sun Apr 27, 2014 8:43 pm
Team Member Top 100
Team Member Top 100
My GPU usually uses a core of cpu to run, but it gets 65-70k ppd when the cpu can only do 12k ish.
Today though, I looked at my CPU and its only at 75-78% the fahcore17 is using barely any cpu. This is strange and although it would be nice if PPD were unaffected, the gpu is only getting 35k...
Any thoughts?
 Post subject: Re: Core 17 not using CPU (slow)
PostPosted: Sun Apr 27, 2014 8:51 pm
Team Member Top 250
Team Member Top 250
How do you have your SMP slot configured? It should be CPU:x, where x is equal to the number of threads minus 1*(# of Folding GPUs). Or possibly the next lowest even number, if your result is a prime number (except 2).
PostPosted: Sun Apr 27, 2014 9:11 pm
also check the tray icon and make sure its set to full, and the slider in advanced control is set to the same.
I have noticed my cpu has stopped running folding for some reason, and have had to right click the cpu info in advanced control, and select fold, sometimes multiple times to get it to restart.
if running windows, I have found that rebooting once a week helps with folding problems
PostPosted: Sun Apr 27, 2014 9:15 pm
Team Member Top 250
Team Member Top 250
Duh! I didn't even think to mention that. I mean, I'm sure he knows that (probably knows what I said, too), but sometimes that slider doesn't seem to be where you want it, especially if you've been using the computer.
PostPosted: Sun Apr 27, 2014 9:28 pm
I never dedicate a core to the gpu, it only uses at the most 2-3% of a single core. I do run evga precision in the tray and it uses about 2% doing nothing but monitoring temps and fan speed.
PostPosted: Sun Apr 27, 2014 9:37 pm
Team Member Top 250
Team Member Top 250
Wow, that's cool. Even on Core_17? Must be some special magic in that 570 and Q9550. Maybe I'm used to seeing an entire core get used is because my procs are older. I gave R3D what I believe to be the old formula (and if my reading at the Folding forums is correct, it's still in play).
Oh, wait, he uses a new AMD GPU, so his overhead should be less, anyways (sorry R3D). I dunno what's going on.
PostPosted: Sun Apr 27, 2014 11:22 pm
Team Member Top 100
Team Member Top 100
Cpu is set for 3 cores since amd cards use 1 too. So 3 for smp plus 1 for gpu is 100%. I looked at usage in the task manager and core a4 is at 75% and core 17 is at 0-2%. Gpu is at 98%, so its def workin on something, but ppd is soooo low for this card.
Slider is maxxed. Only time it isnt is while I game.
PostPosted: Tue Apr 29, 2014 11:53 pm
Team Member Top 250
Team Member Top 250
You know what? I think it goes through phases. Sometimes my GPU PPD numbers tank and TPF and time to completion will jump up. I think as it Folds sometimes it'll use more CPU, sometimes the GPU use will drop away. Since it seems like all the client does is extrapolate from the base point value and the current Folding rate if you catch it during one of those drops the numbers will look bad, but when it gets past that point the numbers will get back to normal. And who knows, some WUs are just worth more points, some are worth less.
PostPosted: Wed Apr 30, 2014 3:20 am
I've noticed considerable variation in my TPF on Core 17 WU, too. Ranging from 9 minutes to 30 minutes, and it is not correlated to my GPU settings. For example, my machine has been folding all night with only background programs running, and I'm at 14'07"... Wondering if, like crwlngkngsnk said, it reflects a particular difficult portion to folding. Also, does anyone know how to interpret the values in the parentheses of the PRCG? for example:
PRCG: 13000 (1903, 0, 18)
I'm assuming 13000 is the project number, but not sure what the values following it represent?
PostPosted: Wed Apr 30, 2014 3:33 am
Team Member Top 250
Team Member Top 250
Each Work Unit is identified using four numbers, in the format: Project(Run, Clone, Generation).
quoted from the FAQ at:https://folding.stanford.edu/home/faq/
What do Run, Clone and Generation mean? Hell, I don't know. I did this much, leave me alone.
*edit*Okay, fine, here:http://fahwiki.net/index.php/Runs%2C_Clones_and_Gens
I haven't read it all yet, my eyes are burning, I'm supposed to be asleep.
PostPosted: Wed Apr 30, 2014 3:19 pm
Thanks! Much obliged, snk!
