It is currently Sat Jan 24, 2015 8:02 pm
 Post subject: Did I set this up right?
PostPosted: Tue Nov 19, 2013 8:09 pm
Hey it's been quite a few months (years) since I've fired up F@H and I just installed the 7.3.6 client. The last time I folded the client was 6.3 and I had it set up to pause using the -pause flag after every WU instead of downloading a new one.
I did some digging and found this:
https://fah-web.stanford.edu/projects/F ... ncesV6ToV7
And then did this:
Does that look right for a global option (as opposed to a per-slot option)?
I also threw in a max-units value of 1 for the folding slot itself and a pause-on-start for the client for the heck of it.
 Post subject: Re: Did I set this up right?
PostPosted: Wed Nov 20, 2013 5:27 am
looks to be a bit of overkill, but just right clicking the client in the interface and choosing 'finish' (iirc) should stop after the current WU.
Welcome back!
PostPosted: Thu Nov 21, 2013 10:24 pm
Overkill is the best kind of kill!
True, right click does do that but I don't want to have to remember to do that every time I start it up. :P
