It is currently Sat Jan 31, 2015 9:42 am
 Post subject: New client is not so great
PostPosted: Sat Nov 16, 2013 5:26 pm
I haven't folded in months on my Linux machine so when I ran it today, I decided to update to the v7.3 from the earlier v7.x version.
Well, took me many install/uninstall figure out that FahControl doesn't turn on the FahClient anymore. You need to run a start/stop command in the terminal (I think it was /etc/init.d/fahclient start).
So after that, I load up the Fahcontrol and I see it got a protein but I can't tell if it's folding or not. It just seems to stay on 0 steps. Is there a way to check if I'm folding? Or maybe they gave me a big WU that my hexacore is slowly crunching thru it? I would have thought it could have done at least 1 step in a half hour.
Thoughts?
 Post subject: Re: New client is not so great
PostPosted: Sun Nov 17, 2013 11:25 am
Location: Rest in Peace... Stratplan & Whitecree & Thomasvjones
I have not done any Folding on a Linux system in a while, but I'll comment on the Windows client.
I don't like what Stanford did with the 7.3.6 client. The new 'Web Control' is an annoying mess.
I reverted several systems back to the 7.2.9 client - I feel it gives me more control over my clients and cores.
There was a forum post somewhere with a link to some of the older clients... but I cannot seem to find it now. :oops:
PostPosted: Sun Nov 17, 2013 1:28 pm
Ok, I also saw that web client thing but didn't really understand what it was all about.
I'll work on it when I get free time. Solving the initial linux problems are a pain though.
PostPosted: Tue Nov 19, 2013 10:03 am
Alright, so it seems that the client was crunching but it just didn't show up in the Control at first.
I also got the GPU to work natively in linux using the 7.3.6 client. You need to give the GPU the slot option of "client-type" with the value of "beta"
More here:
http://forums.pcper.com/showthread.php? ... etup-Guide
So now I got the AMD Phenom II 1045T and an Nvidia GTX 550 ti going. It's probably best to stick to nvidia cards because the AMDs might be troublesome.
PostPosted: Fri Jan 03, 2014 12:37 pm
New client is designed for plug and play, and for newbies, hence the web control.
If you don't like the web control starting every time, edit the startup link to remove the --web gui switch. Then use the tray icon like usual.
As for the linux install, it installs the fahclient as service by default. No need to start a service manually. It starts automatically. No need for fahcontrol to start or start the service, only pause/unpause and quit.
Open fahcontrol and look at the Log tab. It will show you the progress line by line. If you're having trouble, you may need to post a copy of that log anyway to help diagnose the problem.
