It is currently Fri Mar 27, 2015 1:08 am
 Post subject: Folding on TITAN
PostPosted: Thu Feb 28, 2013 5:24 am
Million Club - 20 Plus
Just installed a new EVGA Geforce TITAN. My older v7 client didn't find it so I tried installing the newest client 7.3.6 but it still wasn't found. Fortunately after updating the GPUs.txt (whitelist) I was folding!!
The rig is a 3930K @ 4.3Ghz and running SMP 12 at the same time, so I don't know how accurate any PPD I report will be... but so far the TITAN is getting 28358 PPD on project 7660 (TPF 2min 15sec)
***This PPD is for a TITAN running with the double precision enable in the nvidia control panel (needed for my CUDA apps). If I get a chance I'll run a few projects without it to compare PPD.
Overall I have had to scale back my folding which is unfortunate. This is my only rig running now... but it is better than nothing and it still puts out good numbers!
 Post subject: Re: Folding on TITAN
PostPosted: Thu Feb 28, 2013 5:32 am
So more techy details....
Win 8 x64 reports fahcore15 takes between 0% and 0.1% CPU time.
GPU-z 0.6.7 reports a clock on 823mhz, 1502Mhz memory clock
GPU load of 98% and Memory controller load of 7%.
GPU-z also reports I am running at 62% TDP.... so maybe I will be brave and try OCing
Remember I have double precision enabled in the nvidia control panel.
PostPosted: Thu Feb 28, 2013 6:02 am
*drools over both of those*
Thanks for sharing #s!
PostPosted: Thu Feb 28, 2013 7:37 am
Have you tried switching SMP to 10 (I'd say 11, but in FAH v7 it says to use even numbers). That may help. Your SMP may be lower, but you may more than make up the difference in GPU. In my case, with my 930, it actually increased my SMP by decreasing my setting from 8 or 7 to 6. I run SMP 6 & two GPUs (a 460 & a 650 Ti). Just a suggestion.
PostPosted: Thu Feb 28, 2013 1:21 pm
... just an update... running project 7626 with PPD 51377 ...pretty sweet!
Thanks for the suggestion Gero, I will give 'er a try.
PostPosted: Thu Feb 28, 2013 5:16 pm
2nd
If I had to cut-back to a mere, TITAN I believe I could still sleep at night! Do you game? Congrats, Man! :wink:
Note: And last I read, these cards are relatively effecient. Pat yourself on the back on that account too. Did I wish you, CONGRATS?!!!!!!!!
PostPosted: Tue Apr 02, 2013 6:38 pm
Here are my numbers just folding on my Twin Titans, I dont have the CPU running yet, was trying to see just how much power the titans are pulling.
http://folding.extremeoverclocking.com/user_summary.php?s=&u=119381
PostPosted: Wed Apr 03, 2013 5:05 am
Keep up the great folding!!
Try our your cpu next:) my i7s get anywhere from 20k to 40k PPD
PostPosted: Wed Apr 03, 2013 7:13 pm
Team Member Top 100
Team Member Top 100
nsvander, any idea the wattage you are pulling at the wall with those? The numbers are quite impressive. And to think that QRBs will be added in the near future, reportedly.
PostPosted: Sat Apr 06, 2013 6:15 pm
Full_Taoer,
I truly have no idea, I keeping meaning to grab my amp clamp and hook it up to see. I will grab it monday from work, an see what power use is.
