It is currently Sun May 03, 2015 4:18 pm
 Post subject: How many processes should I run?
PostPosted: Wed Aug 04, 2004 8:25 am
I am putting FAH on a dually rig I have sitting down almost nothing ... I use it for testing some networking code for the most part, and for checking my mail and surfing when in the TV room.
It is a Dual P3/850 ... not overclocked ... with 512MB of RAM running Gentoo with the 2.6.7 kernel. So ... should I be running 2 processes? One for each CPU? More?
PostPosted: Wed Aug 04, 2004 8:29 am
Professional Dork
Professional Dork
You want to use 2 processes. I highly recommend 2 CLI processes.
Set each to have its own processor affinity. Start a process, set its affinity to CPU 0. Then start the other process and set its affinity to CPU 1
Also make sure you run each instance in its own folder. I use /fah0 and /fah1, and make sure you use the "-local -forceasm -forcesse" flag structure.
PostPosted: Wed Aug 04, 2004 8:39 am
Thanks. :)
Am now running it on two machines. I got all excited 'n' shit.
(my roommate isn't home ... I'm considering installing it on his machine and trying to set it up as a hidden process ... :lol: ... probably not a good idea though)
PostPosted: Wed Aug 04, 2004 4:50 pm
information, apparantly you dont need to set affinity, we have been running 3 p4s and 2 xeons hyperthreaded and dont set affinity on any of them they just go to 50% on the p4s and 25% on the xeons (dual) on their own.
PostPosted: Wed Aug 04, 2004 7:40 pm
I Hope that's true I've notciced that but still Set affinity to by sure the Tasks don't mix, be nice if you didnot have too.
PostPosted: Thu Aug 05, 2004 4:34 am
Professional Dork
Professional Dork
Setting affinity isn't absolutely necessary (and in theory it shouldn't be necessary at all), but according to [Ch]ams and his tweaking guide, it seems to run better if you do set affinity.
