It is currently Sat May 18, 2013 10:52 am
 Post subject: Why is my average PPD dropping???
PostPosted: Fri Nov 23, 2012 8:13 pm
Okay, it's a loaded question to which I already know the answer... but if any of you were pondering that question and folding on a GPU, here's the cause. GPU core version 2.25 was just released. They are working on Kepler optimizations & so it seems that Fermi cards are suffering, this should only be a temporary situation as they work the bugs out & release even newer cores in the near future.
Performance under 2.25 for me personally is horrific. I'm talking up to 2 minutes per frame & 5,000 ppd worse than the same work units under core version 2.22. Stanford / Pande Group already know about the performance drop & were apparently expecting it. All we can do is either stop folding on the GPU & watch our average ppd drop even more, or wait for the next core update to come out.
 Post subject: Re: Why is my average PPD dropping???
PostPosted: Sun Nov 25, 2012 11:09 am
Appreaciate your taking the time to keep us updated on your thoughts of the differing "core versions" and their ramifications. Frankly, I'm more of a mechanic than a programming geek, etc. Bottom line "from your interpretations" we're in for at least a small dry spell in PPD and a certain amount of frustration in the use of Fermi gpus in f@h". Like I've already said though "it's good to know, with some certainty", WTF is going on, when my mechanicing hardly, if at all, succeeds to makes a dent in my personal, PPD.
Tell you what... if you and others are willing to help keep us in the know academically, in what's taking place, I'm willing to keep my machines tuned accordingly and hopefully in the right direction, for the good of the Team and of course, the Science, which keeps us in a common search for anything to stimulate Scientests' and Doctors' minds toward piecing together cures for us, our children and grandchildren.
Appreaciate the update.
PostPosted: Mon Nov 26, 2012 6:24 am
one thing that can be done is to revert back to the 2.22 core. That will help until the newer version gets downloaded again. A huge help is to fold beta units with a quick return bonus (QRB) (from all the buzz on the other forums). I've done the changes, but have had no joy yet. Maybe I didn't do something correctly. Here is the link on what to do to add the appropriate flags:
http://hardforum.com/showthread.php?t=1727789
If you end up getting a unit, the points seem to be 3-4x 'normal'.
PostPosted: Mon Nov 26, 2012 8:18 am
That would require some 'not quite kosher' hijinks. When 2.25 is downloaded, it replaces 2.22 & no backup of 2.22 is made, so the only way to get back to 2.22 is to copy it from a PC that has core version 2.22, but hasn't been running GPU units. Then you would have to do a few things that are against Stanford's terms of use...
Stanford is the big looser here with production reduced by as much as 40% on certain cards, that means that every day 2.25 is live, they are getting fewer completed GPU work units turned in. Fewer work units means slower progress on the science side of things.
PostPosted: Mon Nov 26, 2012 9:32 am
from what I saw on the [H] thread, they have updated v7 to use seperate folders for the 2.22 & 2.25. I think that there is a post on the [H] thread about it.
http://hardforum.com/showpost.php?p=103 ... tcount=255
more info on the new scoring on the folding forum:
http://foldingforum.org/viewtopic.php?f=66&t=22808
PostPosted: Mon Nov 26, 2012 11:53 am
Bottom line is: that is a form of cheating, & though not strictly worded as being against the terms of use, they are skirting past the bounds of Stanford's wishes, kind of like folding "BigAdv" work units on 12-core systems through Virtual Machines.
If I hear correctly, current GPU work units will require a minimum core version of 2.25 in order to fold in the very near future... This means that anyone trying to work around it will simply not be able to fold.
PostPosted: Mon Nov 26, 2012 12:54 pm
I wouldn't really see it as cheating. The 2.22 version works better with Fermi cards and the 2.25 version doesn't work as well with Fermi, but seems to work better with Kepler. Yes, the newer WUs will force download the newer version, but I wouldn't try to stop that from happening. I'd wager that if Stanford wanted everyone to only be able to use the 2.25 core, they could likely do that. A 30-40% hit on PPD sucks any way you slice it.
Technically, overclocking a CPU or GPU is 'cheating' (by one entity or another). The point is that people still do it and it is generally accepted as a fine thing to do. I'm not here to argue about the ethics of swapping out one version for another of a core, I'm just letting people know that the possibility is out there for better performance. I haven't even done it myself.
On another point, I can't wait until the 'equal points for equal work' on the GPUs comes into full effect. From what I have seen, this is why the whole 3-5x points thing came up. I've got 3 GPUs waiting for the bump :)
PostPosted: Mon Nov 26, 2012 10:51 pm
Like I said, if I hear correctly, they're already working on it. However the WU's that were already on the servers only require 2.22 & still need to be folded. Those could run out tonight, next week, next month...
The only entity that matters is Stanford and they say overclocking is fine. It's like drag racing... if the governing body of a given race says Nos is fine to use, then it's not cheating if you use it, but if they say it's against the rules, and you use it anyway, you can be thrown out of the competition without compensation, & potentially banned from future competitions.
The difference between overclocking & what [H] does & you're suggesting, is that Stanford says overclocking is fine, but has asked that we not tamper with the client or the cores. Replacing a newer core with an older core is a form of tampering.
If all you care about is the points, then go ahead & swap out those cores.
PostPosted: Tue Nov 27, 2012 6:09 am
Correct. I think they are already 'reigning in' the points. I have gotten a few of the units now and the points don't seem to be quite as high as what I've seen reported (though they are pretty nice :twisted: )
In this case, the units that need the newer version of the core do a check and download the new version if it isn't present. Also, more science is able to be done with the older core (better TPF). While I don't do it, swapping could be seen as beneficial in that way (as well as in PPD). If Stanford explicitly said not to do it, I'd agree with them on that, but I haven't seen that they have.
I was just bringing it to the attention of the readers that you could get a good bump by adding the beta flag and also a little more bump by swapping.
From what I've read and see by dropping PPD, the newer core version performs ~30-40%+ worse when compared to the older version. Swapping has no ill effects on the amount of science done, and arguably has positive effects via quicker turn-around for WUs (and thus higher PPD).
If Stanford were really concerned they would have done better testing on the core version as to not hurt turn-around time so greatly on WUs already in the wild.
PostPosted: Tue Nov 27, 2012 7:34 am
And for that I say THANK YOU Two 8057's back to back averaging about 14,420 points credit & at 3min 22.3sec per frame, that's an average of more than 61,000ppd.
Spoiler: show
*********************** Log Started 2012-11-25T04:05:40Z ***********************
04:05:40:************************* Folding@home Client *************************
04:05:40: Website: http://folding.stanford.edu/
04:05:40: Copyright: (c) 2009-2012 Stanford University
04:05:40: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:05:40: Args: --lifeline 5236 --command-port=36330
04:05:40: Config: C:/Users/chaosdsm/AppData/Roaming/FAHClient/config.xml
04:05:40:******************************** Build ********************************
04:05:40: Version: 7.1.52
04:05:40: Date: Mar 20 2012
04:05:40: Time: 19:37:42
04:05:40: SVN Rev: 3515
04:05:40: Branch: fah/trunk/client
04:05:40: Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:05:40: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:05:40: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
04:05:40: Platform: win32 XP
04:05:40: Bits: 32
04:05:40: Mode: Release
04:05:40:******************************* System ********************************
04:05:40: CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
04:05:40: CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
04:05:40: CPUs: 12
04:05:40: Memory: 15.95GiB
04:05:40: Free Memory: 14.17GiB
04:05:40: Threads: WINDOWS_THREADS
04:05:40: On Battery: false
04:05:40: UTC offset: -5
04:05:40: PID: 1036
04:05:40: CWD: C:/Users/chaosdsm/AppData/Roaming/FAHClient
04:05:40: OS: Windows 7 Professional
04:05:40: OS Arch: AMD64
04:05:40: GPUs: 1
04:05:40: GPU 0: FERMI:1 GF104 [GeForce GTX 460]
04:05:40: CUDA: 2.1
04:05:40: CUDA Driver: 5000
04:05:40:Win32 Service: false
04:05:40:***********************************************************************
04:05:40:<config>
04:05:40: <!-- Folding Slot Configuration -->
04:05:40: <gpu v='true'/>
04:05:40:
04:05:40: <!-- Network -->
04:05:40: <proxy v=':8080'/>
04:05:40:
04:05:40: <!-- User Information -->
04:05:40: <passkey v='********************************'/>
04:05:40: <team v='11108'/>
04:05:40: <user v='chaosdsm'/>
04:05:40:
04:05:40: <!-- Folding Slots -->
04:05:40: <slot id='0' type='GPU'/>
04:05:40: <slot id='1' type='SMP'>
04:05:40: <cpus v='-1'/>
04:05:40: </slot>
04:05:40:</config>
04:05:40:Trying to access database...
04:05:40:Successfully acquired database lock
04:05:40:Enabled folding slot 00: READY gpu:0:"GF104 [GeForce GTX 460]"
04:05:40:Enabled folding slot 01: READY smp:12
07:59:06:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
07:59:06:WU00:FS00:News: Welcome to Folding@Home
07:59:06:WU00:FS00:Assigned to work server 171.67.108.144
07:59:06:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF104 [GeForce GTX 460]" from 171.67.108.144
07:59:06:WU00:FS00:Connecting to 171.67.108.144:8080
07:59:06:WU00:FS00:Downloading 56.90KiB
07:59:07:WU00:FS00:Download complete
07:59:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8057 run:0 clone:187 gen:35 core:0x15 unit:0x000000296953ee30508b38acc9480924
07:59:07:WU00:FS00:Downloading project 8057 description
07:59:07:WU00:FS00:Connecting to fah-web.stanford.edu:80
07:59:08:WU00:FS00:Project 8057 description downloaded successfully
07:59:18:WU00:FS00:Starting
07:59:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe"
C:/Users/chaosdsm/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 701 -lifeline
1036 -checkpoint 15 -gpu 0
07:59:18:WU00:FS00:Started FahCore on PID 3880
07:59:18:WU00:FS00:Core PID:3128
07:59:18:WU00:FS00:FahCore 0x15 started
07:59:18:WU00:FS00:0x15:
07:59:18:WU00:FS00:0x15:*------------------------------*
07:59:18:WU00:FS00:0x15:Folding@Home GPU Core
07:59:18:WU00:FS00:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
07:59:18:WU00:FS00:0x15:Build host AmoebaRemote
07:59:18:WU00:FS00:0x15:Board Type NVIDIA/CUDA
07:59:18:WU00:FS00:0x15:Core 15
07:59:18:WU00:FS00:0x15:Window's signal control handler registered.
07:59:18:WU00:FS00:0x15:Preparing to commence simulation
07:59:18:WU00:FS00:0x15:- Looking at optimizations...
07:59:18:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
07:59:18:WU00:FS00:0x15:- Created dyn
07:59:18:WU00:FS00:0x15:- Files status OK
07:59:18:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
07:59:18:WU00:FS00:0x15:- Expanded 57756 -> 261042 (decompressed 451.9 percent)
07:59:18:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=57756 data_size=261042, decompressed_data_size=261042 diff=0
07:59:18:WU00:FS00:0x15:- Digital signature verified
07:59:18:WU00:FS00:0x15:Project: 8057 (Run 0, Clone 187, Gen 35)
07:59:18:WU00:FS00:0x15:Assembly optimizations on if available.
07:59:18:WU00:FS00:0x15:Entering M.D.
07:59:20:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr: 4029547109 1412313508 17463167 2522816081 3265491831
07:59:20:WU00:FS00:0x15:GPU device id=0
07:59:20:WU00:FS00:0x15:Working on Giving Russians Opium May Alter Current Situation
07:59:20:WU00:FS00:0x15:Client config unavailable.
07:59:20:WU00:FS00:0x15:Starting GUI Server
08:00:21:WU00:FS00:0x15:Setting checkpoint frequency: 500000
08:00:21:WU00:FS00:0x15:Completed 3 out of 50000000 steps (0%).
08:03:43:WU00:FS00:0x15:Completed 500000 out of 50000000 steps (1%).
08:07:05:WU00:FS00:0x15:Completed 1000000 out of 50000000 steps (2%).
08:10:27:WU00:FS00:0x15:Completed 1500000 out of 50000000 steps (3%).
08:13:50:WU00:FS00:0x15:Completed 2000000 out of 50000000 steps (4%).
08:17:12:WU00:FS00:0x15:Completed 2500000 out of 50000000 steps (5%).
08:20:34:WU00:FS00:0x15:Completed 3000000 out of 50000000 steps (6%).
08:23:56:WU00:FS00:0x15:Completed 3500000 out of 50000000 steps (7%).
08:27:18:WU00:FS00:0x15:Completed 4000000 out of 50000000 steps (8%).
08:30:41:WU00:FS00:0x15:Completed 4500000 out of 50000000 steps (9%).
08:34:03:WU00:FS00:0x15:Completed 5000000 out of 50000000 steps (10%).
13:03:37:WU00:FS00:0x15:Completed 45000000 out of 50000000 steps (90%).
13:06:59:WU00:FS00:0x15:Completed 45500000 out of 50000000 steps (91%).
13:10:21:WU00:FS00:0x15:Completed 46000000 out of 50000000 steps (92%).
13:13:43:WU00:FS00:0x15:Completed 46500000 out of 50000000 steps (93%).
13:17:05:WU00:FS00:0x15:Completed 47000000 out of 50000000 steps (94%).
13:20:28:WU00:FS00:0x15:Completed 47500000 out of 50000000 steps (95%).
13:23:50:WU00:FS00:0x15:Completed 48000000 out of 50000000 steps (96%).
13:27:12:WU00:FS00:0x15:Completed 48500000 out of 50000000 steps (97%).
13:30:34:WU00:FS00:0x15:Completed 49000000 out of 50000000 steps (98%).
13:33:56:WU00:FS00:0x15:Completed 49500000 out of 50000000 steps (99%).
13:37:19:WU00:FS00:0x15:Completed 50000000 out of 50000000 steps (100%).
13:37:19:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:37:19:WU00:FS00:0x15:Finished fah_main status=0
13:37:19:WU00:FS00:0x15:Successful run
13:37:19:WU00:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
13:37:19:WU02:FS00:News: Welcome to Folding@Home
13:37:19:WU02:FS00:Assigned to work server 171.67.108.144
13:37:19:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF104 [GeForce GTX 460]" from 171.67.108.144
13:37:19:WU02:FS00:Connecting to 171.67.108.144:8080
13:37:20:WU02:FS00:Downloading 56.84KiB
13:37:20:WU02:FS00:Download complete
13:37:20:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:8057 run:0 clone:606 gen:29 core:0x15 unit:0x0000001f6953ee30508b38c916b2bb0f
13:37:29:WU00:FS00:0x15:Reserved 326704 bytes for xtc file; Cosm status=0
13:37:29:WU00:FS00:0x15:Allocated 326704 bytes for xtc file
13:37:29:WU00:FS00:0x15:- Reading up to 326704 from "00/wudata_01.xtc": Read 326704
13:37:29:WU00:FS00:0x15:Read 326704 bytes from xtc file; available packet space=786103760
13:37:29:WU00:FS00:0x15:xtc file hash check passed.
13:37:29:WU00:FS00:0x15:Reserved 20400 20400 786103760 bytes for arc file=<00/wudata_01.trr> Cosm status=0
13:37:29:WU00:FS00:0x15:Allocated 20400 bytes for arc file
13:37:29:WU00:FS00:0x15:- Reading up to 20400 from "00/wudata_01.trr": Read 20400
13:37:29:WU00:FS00:0x15:Read 20400 bytes from arc file; available packet space=786083360
13:37:29:WU00:FS00:0x15:trr file hash check passed.
13:37:29:WU00:FS00:0x15:Allocated 544 bytes for edr file
13:37:29:WU00:FS00:0x15:Read bedfile
13:37:29:WU00:FS00:0x15:edr file hash check passed.
13:37:29:WU00:FS00:0x15:Allocated 36779 bytes for logfile
13:37:29:WU00:FS00:0x15:Read logfile
13:37:29:WU00:FS00:0x15:GuardedRun: success in DynamicWrapper
13:37:29:WU00:FS00:0x15:GuardedRun: done
13:37:29:WU00:FS00:0x15:Run: GuardedRun completed.
13:37:30:WU00:FS00:0x15:+ Opened results file
13:37:30:WU00:FS00:0x15:- Writing 384939 bytes of core data to disk...
13:37:30:WU00:FS00:0x15:Done: 384427 -> 353282 (compressed to 91.8 percent)
13:37:30:WU00:FS00:0x15: ... Done.
13:37:30:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
13:37:30:WU00:FS00:0x15:Shutting down core
13:37:30:WU00:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
13:37:31:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:37:31:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:8057 run:0 clone:187 gen:35 core:0x15 unit:0x000000296953ee30508b38acc9480924
13:37:31:WU00:FS00:Uploading 345.50KiB to 171.67.108.144
13:37:31:WU00:FS00:Connecting to 171.67.108.144:8080
13:37:31:WU02:FS00:Starting
13:37:31:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe"
C:/Users/chaosdsm/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 701 -lifeline
13:37:31:WU02:FS00:Started FahCore on PID 4056
13:37:31:WU02:FS00:Core PID:5580
13:37:31:WU02:FS00:FahCore 0x15 started
13:37:31:WU02:FS00:0x15:
13:37:31:WU02:FS00:0x15:*------------------------------*
13:37:31:WU02:FS00:0x15:Folding@Home GPU Core
13:37:31:WU02:FS00:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
13:37:31:WU02:FS00:0x15:Build host AmoebaRemote
13:37:31:WU02:FS00:0x15:Board Type NVIDIA/CUDA
13:37:31:WU02:FS00:0x15:Core 15
13:37:31:WU02:FS00:0x15:Window's signal control handler registered.
13:37:31:WU02:FS00:0x15:Preparing to commence simulation
13:37:31:WU02:FS00:0x15:- Looking at optimizations...
13:37:31:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
13:37:31:WU02:FS00:0x15:- Created dyn
13:37:31:WU02:FS00:0x15:- Files status OK
13:37:31:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
13:37:31:WU02:FS00:0x15:- Expanded 57696 -> 261042 (decompressed 452.4 percent)
13:37:31:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=57696 data_size=261042, decompressed_data_size=261042 diff=0
13:37:31:WU02:FS00:0x15:- Digital signature verified
13:37:31:WU02:FS00:0x15:Project: 8057 (Run 0, Clone 606, Gen 29)
13:37:31:WU02:FS00:0x15:Assembly optimizations on if available.
13:37:31:WU02:FS00:0x15:Entering M.D.
13:37:32:WU00:FS00:Upload complete
13:37:32:WU00:FS00:Server responded WORK_ACK (400)
13:37:32:WU00:FS00:Final credit estimate, 14399.00 points
13:37:32:WU00:FS00:Cleaning up
13:37:33:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr: 3516951991 589049473 1866187918 3733578281 3945623822
13:37:33:WU02:FS00:0x15:GPU device id=0
13:37:33:WU02:FS00:0x15:Working on Giving Russians Opium May Alter Current Situation
13:37:33:WU02:FS00:0x15:Client config unavailable.
13:37:33:WU02:FS00:0x15:Starting GUI Server
13:38:33:WU02:FS00:0x15:Setting checkpoint frequency: 500000
13:38:33:WU02:FS00:0x15:Completed 3 out of 50000000 steps (0%).
13:41:56:WU02:FS00:0x15:Completed 500000 out of 50000000 steps (1%).
13:45:18:WU02:FS00:0x15:Completed 1000000 out of 50000000 steps (2%).
13:48:40:WU02:FS00:0x15:Completed 1500000 out of 50000000 steps (3%).
13:52:02:WU02:FS00:0x15:Completed 2000000 out of 50000000 steps (4%).
13:55:24:WU02:FS00:0x15:Completed 2500000 out of 50000000 steps (5%).
13:58:46:WU02:FS00:0x15:Completed 3000000 out of 50000000 steps (6%).
14:02:08:WU02:FS00:0x15:Completed 3500000 out of 50000000 steps (7%).
14:05:31:WU02:FS00:0x15:Completed 4000000 out of 50000000 steps (8%).
14:08:53:WU02:FS00:0x15:Completed 4500000 out of 50000000 steps (9%).
14:12:15:WU02:FS00:0x15:Completed 5000000 out of 50000000 steps (10%).
EDIT: Hm... looks like the "Code" tags need to be altered so that they display like they do over at Stanford's forums & don't unnecessarily lengthen the posts... replaced with "spoiler" tags.
PostPosted: Tue Nov 27, 2012 10:50 am
I seem to have left the 5187 PPD wus behind. I folded those for about a week before adding the beta flag. I downloaded a 8*** wu last night, worth over 100,000 PPD. On average, my PPD doubled! http://folding.extremeoverclocking.com/ ... =&u=137527
Thanks, for the tip! :)
PostPosted: Tue Nov 27, 2012 12:23 pm
jack5995 wrote:
... On average, my PPD doubled! http://folding.extremeoverclocking.com/ ... =&u=137527
You're welcome! We're a month behind on the news, but I've seen a handful of the 8057s and I'm happy too! Over the past 24 hours, I'm around 81k PPD. Beats the heck out of 45-50k PPD :twisted:
