It is currently Sat Jan 31, 2015 1:49 am
 Post subject: New Fah_Core
PostPosted: Fri Jul 30, 2004 7:15 am
Right now I'm running Fah_Core 65. Does anyone know where I can get a newer core? I can't find it anywhere on the Folding@Home site.
 Post subject: Re: New Fah_Core
PostPosted: Fri Jul 30, 2004 8:26 am
Bitchin' Fast 3D Z8000*
http://www.stanford.edu/group/pandegrou ... nload.html
PostPosted: Fri Jul 30, 2004 8:30 am
Tried it. I'm still using Fah_Core 65. Are the newer cores faster?
PostPosted: Fri Jul 30, 2004 8:59 am
I don't know.
PostPosted: Fri Jul 30, 2004 10:27 am
Max [Ph]otographer
Max [Ph]otographer
The core is downloaded automatically from the server. The only thing you can download is a new client, which has nothing to do with the core.
Cores are automatically updated once there is a new one on the server. There is no need to go and force a new core.
Dan O.
PostPosted: Fri Jul 30, 2004 12:14 pm
Super Folder
Super Folder
Just in case you don't automatically download a new core, just delete your current one. F@H will download the newest one for you when it restarts
PostPosted: Fri Jul 30, 2004 1:26 pm
doesn't folding@home automatically decide which core is best for running on ur computer and use that one? i know for a fact that my computers with AMDs are running a different core than my comps running Intels, my AMds use core 78 and 65 while my intels use core 65
PostPosted: Fri Jul 30, 2004 1:37 pm
Team Member Top 100
Team Member Top 100
The WU will use whatever core is required to get the job done. I have 78 and 65 on both my Intel and amd rigs.
I think core 78 is for Gromacs and 65 is for Tinkers.
Taken from MaximumPC's Folding at Home Tweaker's Guide
Quote:
Get a new core
Whenever you upgrade to a new client version, it's a good idea also to delete your FahCorexx.exe files (where xx represents a two-digit number). The FahCore files are located in the folder in which Folding at Home is installed, usually C:/Program Files/Folding@Home. By deleting the core files, you ensure that Folding at Home will download the latest version of the required core. Since the core file is the program that actually performs the folding simulation, you definitely want to be using the latest release.
PostPosted: Fri Jul 30, 2004 6:10 pm
Quote:
Get a new core
"I think core 78 is for Gromacs and 65 is for Tinkers. "
You are correct. :D
