It is currently Mon May 20, 2013 9:11 am
 Post subject: HFM.net help
PostPosted: Sun Sep 16, 2012 9:18 pm
Folding Master (Top-ranked)
Can anyone point me to some setup instructions for version .9 HFM? I have a couple of clients folding with fah v7. I don't know what to put in for name or address. I think the address should be the ip so I must be messing up with the name. I can get it to monitor the gpu clients OK but not fah.. I would like to monitor the home network and this laptop. I will worry about my remote computer later.
 Post subject: Re: HFM.net help
PostPosted: Mon Sep 17, 2012 8:03 pm
Team Member Top 100
Team Member Top 100
This may help. It's an excerpt from a thread in Harlam's Google group. Like DocJonz, I'd prefer a Dummies guide. :lol:
Quote:
DocJonz Join group to reply
Apr 9
I've installed the new HFM.NET and added all the v6 clients quite
happily, but have a few questions regarding adding the v7 ones.
Assume that I have two PC's - PC1 (WinXP) and PC2 (Linux - Ubuntu),
both using the default Folding directories.
I made a share on PC1 to 'user', for example, and then tried;
//PC1/user/Application Data/FAHClient
but this didn't work. Am I barking up the wrong tree? I didn't want to
use the IP address as these are dynamic.
Similarly, on the Linux machine, the Folding files appear to be
installed in /usr/bin/, but this area doesn't like to be shared (I'm
assuming I need to share it first?).
Do you have a dummies guide for doing this sort of thing?!
MtM Join group to reply
Apr 9
RE: [hfm-net] Monitoring v7 Clients
Try adding the client using the netbios name, you don't use shared folders
as HFM.net uses the client remote interface exclusively.
- show quoted text -
You received this message because you are subscribed to the Google Groups
"hfm-net" group.
To unsubscribe from this group, send email to
hfm-net+u...@googlegroups.com
For more options, visit this group at
http://groups.google.com/group/hfm-net?hl=en
harlam357 Join group to reply
Apr 9
Re: [hfm-net] Monitoring v7 Clients
Hi Doc,
Sorry, no dummies guide. We're all smart people, we don't need
dummies guides. :-)
Marvin is correct. All you need is the hostname or IP address, port,
and password (if applicable). Also, you'll likely need to allow
access for remote connections for each v7 client. By default the v7
client allows connections from the local machine only. When opening
FAHControl on each v7 client you'll need to allow connections from IPs
other than 127.0.0.1 (loopback). Go to the client configuration in
FAHControl and then the "Remote Access" (can't remember if that's
exactly right off hand) tab. The easiest thing to do is add access
for your entire subnet. In my case this is "192.168.0.0/24". Adjust
accordingly for yours.
Kind Regards,
-H
PostPosted: Tue Sep 18, 2012 2:08 am
Is there other monitoring software. I don't get what you are talking about.
PostPosted: Wed Sep 19, 2012 8:01 pm
Team Member Top 100
Team Member Top 100
I had hoped you would find a tip in the responses to the question posed in the quote above. Sorry I'm not more helpful on this one. I haven't installed v9 of HFM. If I can get it done this weekend, maybe I can weigh in more informed.
Users browsing this forum: Google [Bot] and 3 guests
