It is currently Sat Jan 31, 2015 8:22 am
 Post subject: Folding as system service
PostPosted: Wed Jun 27, 2012 5:00 am
Is there any benefit in upgrading the folding client when it runs as a system service from version 6.34 to the new version 7?
 Post subject: Re: Folding as system service
PostPosted: Wed Jun 27, 2012 6:54 pm
Team Member Top 100
Team Member Top 100
I do not see any compelling reason to upgrade a system service install at this point. The same WUs are available to both AFIK. The main functional difference is V7.x can pre-download the next WU and queue it up for a quicker transition from one to the next. The effect on bonus points will vary, since the bonus is calculated on download time, not the start of crunching.
PostPosted: Thu Jun 28, 2012 4:41 am
thanks for reply, will save me a lot of work, sitting on gigabit lines dont think download/upload time is a bottleneck.
When installing on fresh images or new PC i should perhaps go for version 7 then, its just that i think its easier to set appropriate flags etc with version 6, maybe its an easier way of doing it with version 7 than to enter the GUI and add additional flags like max_packet_size big ?
PostPosted: Sat Jun 30, 2012 6:17 pm
I'm with you. There's a little bit of a learning curve with the console, but it doesn't take long and you're running like a pro.
When I tried it, I found the v7 GUI to be clunky and think that it actually takes longer to do things than console once you reach that familiarity.
Also, I prefer the service option, as it prevents the family from messing any of it up.
PostPosted: Tue Jul 03, 2012 5:28 pm
So run V7 as a service.
And once it's configured, you never mess with it anyway, so who cares about a so called clunky gui. It's set and forget anyway.
You'll want to upgrade when it's convenient, not when you have to. Sooner is better than later. ;)
