It is currently Mon Jan 26, 2015 9:35 am
 Post subject: New Public V7 Beta to be Released
PostPosted: Wed Mar 21, 2012 10:46 am
Folding for Elena
Folding for Elena
On foldingforum.org, version 7.1.52 is now out, which they say will be the first public stable beta to be released for Version 7 of the Folding Client. Get it NOW on the website.
 Post subject: Re: New Public V7 Beta to be Released
PostPosted: Thu Mar 22, 2012 6:25 am
Got it.
It's right on the top of the main page. They have redone the Stanford folding main page, at least the first page you are taken to right now before the main. "Ready, Set, Fold," Click on the big middle button and you immediately start downloading 7.1.52. It doesn't get any easier than this.
PostPosted: Thu Mar 22, 2012 8:31 am
Downloaded and installed, im just not very used to version 7 yet so Im wondering if i set up the flags correctly.
As it is now its like
under configure -> slots -> folding slots (smp) -> I have put under extra slots options (expert only) "client-type - advanced"
under configure -> Expert -> Extra client options -> I have added two flags "client-type : bigadv" and "max-packet-size : big"
I havent added anything under the extra core options.
The log looks like this
16:16:58:******************************** Build ********************************
16:16:58: Version: 7.1.52
16:16:58: Date: Mar 20 2012
16:16:58: Time: 19:37:42
16:16:58: SVN Rev: 3515
16:16:58: Branch: fah/trunk/client
16:16:58: Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:16:58: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:16:58: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
16:16:58: Platform: win32 XP
16:16:58: Bits: 32
16:16:58: Mode: Release
16:16:58:******************************* System ********************************
16:16:58: CPU: Intel(R) Xeon(R) CPU E7- 8837 @ 2.67GHz
16:16:58: CPU ID: GenuineIntel Family 6 Model 47 Stepping 2
16:16:58: CPUs: 32
16:16:58: Memory: 255.99GiB
16:16:58: Free Memory: 243.98GiB
16:16:58: Threads: WINDOWS_THREADS
16:16:58: On Battery: false
16:16:58: UTC offset: 1
16:16:58: PID: 4292
16:16:58: CWD: C:/xxx
16:16:58: OS: Windows Server 2008 R2 Enterprise
16:16:58: OS Arch: AMD64
16:16:58: GPUs: 0
16:16:58: CUDA: Not detected
16:16:58:Win32 Service: false
16:16:58:***********************************************************************
16:16:58:<config>
16:16:58: <service-description v='Folding@home Client'/>
16:16:58: <service-restart v='true'/>
16:16:58: <service-restart-delay v='5000'/>
16:16:58:
16:16:58: <!-- Client Control -->
16:16:58: <cycle-rate v='4'/>
16:16:58: <cycles v='-1'/>
16:16:58: <data-directory v='.'/>
16:16:58: <disable-project-lookup v='false'/>
16:16:58: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
16:16:58: <exit-when-done v='false'/>
16:16:58: <threads v='4'/>
16:16:58:
16:16:58: <!-- Configuration -->
16:16:58: <config-rotate v='true'/>
16:16:58: <config-rotate-dir v='configs'/>
16:16:58: <config-rotate-max v='16'/>
16:16:58:
16:16:58: <!-- Debugging -->
16:16:58: <assignment-servers>
16:16:58: assign3.stanford.edu:8080 assign4.stanford.edu:80
16:16:58: </assignment-servers>
16:16:58: <capture-directory v='capture'/>
16:16:58: <capture-sockets v='false'/>
16:16:58: <debug-sockets v='false'/>
16:16:58: <exception-locations v='true'/>
16:16:58: <gpu-assignment-servers>
16:16:58: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
16:16:58: </gpu-assignment-servers>
16:16:58: <stack-traces v='false'/>
16:16:58:
16:16:58: <!-- Error Handling -->
16:16:58: <max-slot-errors v='5'/>
16:16:58: <max-unit-errors v='5'/>
16:16:58:
16:16:58: <!-- FahCore Control -->
16:16:58: <checkpoint v='15'/>
16:16:58: <core-dir v='cores'/>
16:16:58: <core-priority v='idle'/>
16:16:58: <cpu-affinity v='false'/>
16:16:58: <cpu-usage v='100'/>
16:16:58: <no-assembly v='false'/>
16:16:58:
16:16:58: <!-- Folding Slot Configuration -->
16:16:58: <client-subtype v='STDCLI'/>
16:16:58: <client-type v='bigadv'/>
16:16:58: <cpu-species v='X86_PENTIUM_II'/>
16:16:58: <cpu-type v='AMD64'/>
16:16:58: <cpus v='-1'/>
16:16:58: <cuda-index v='0'/>
16:16:58: <gpu v='false'/>
16:16:58: <gpu-usage v='100'/>
16:16:58: <max-packet-size v='big'/>
16:16:58: <opencl-index v='0'/>
16:16:58: <os-species v='UNKNOWN'/>
16:16:58: <os-type v='WIN32'/>
16:16:58: <project-key v='0'/>
16:16:58: <smp v='true'/>
16:16:58:
16:16:58: <!-- Logging -->
16:16:58: <log v='log.txt'/>
16:16:58: <log-color v='false'/>
16:16:58: <log-crlf v='true'/>
16:16:58: <log-date v='false'/>
16:16:58: <log-date-periodically v='21600'/>
16:16:58: <log-debug v='true'/>
16:16:58: <log-domain v='false'/>
16:16:58: <log-header v='true'/>
16:16:58: <log-level v='true'/>
16:16:58: <log-no-info-header v='true'/>
16:16:58: <log-redirect v='false'/>
16:16:58: <log-rotate v='true'/>
16:16:58: <log-rotate-dir v='logs'/>
16:16:58: <log-rotate-max v='16'/>
16:16:58: <log-short-level v='false'/>
16:16:58: <log-simple-domains v='true'/>
16:16:58: <log-thread-id v='false'/>
16:16:58: <log-thread-prefix v='true'/>
16:16:58: <log-time v='true'/>
16:16:58: <log-to-screen v='true'/>
16:16:58: <log-truncate v='false'/>
16:16:58: <verbosity v='5'/>
16:16:58:
16:16:58: <!-- Network -->
16:16:58: <proxy v=':8080'/>
16:16:58: <proxy-enable v='false'/>
16:16:58: <proxy-pass v=''/>
16:16:58: <proxy-user v=''/>
16:16:58:
16:16:58: <!-- Process Control -->
16:16:58: <child v='false'/>
16:16:58: <daemon v='false'/>
16:16:58: <pid v='false'/>
16:16:58: <pid-file v='Folding@home Client.pid'/>
16:16:58: <respawn v='false'/>
16:16:58: <service v='false'/>
16:16:58:
16:16:58: <!-- Remote Command Server -->
16:16:58: <command-address v='0.0.0.0'/>
16:16:58: <command-allow v='127.0.0.1'/>
16:16:58: <command-allow-no-pass v='127.0.0.1'/>
16:16:58: <command-deny v='0.0.0.0/0'/>
16:16:58: <command-deny-no-pass v='0.0.0.0/0'/>
16:16:58: <command-port v='36330'/>
16:16:58:
16:16:58: <!-- Slot Control -->
16:16:58: <max-shutdown-wait v='60'/>
16:16:58: <pause-on-battery v='false'/>
16:16:58: <pause-on-start v='false'/>
16:16:58:
16:16:58: <!-- User Information -->
16:16:58: <machine-id v='0'/>
16:16:58: <passkey v='********************************'/>
16:16:58: <team v='11108'/>
16:16:58: <user v='WikingTOR'/>
16:16:58:
16:16:58: <!-- Work Unit Control -->
16:16:58: <dump-after-deadline v='true'/>
16:16:58: <max-queue v='16'/>
16:16:58: <max-units v='0'/>
16:16:58: <next-unit-percentage v='99'/>
16:16:58:
16:16:58: <!-- Folding Slots -->
16:16:58: <slot id='0' type='SMP'>
16:16:58: <client-type v='advanced'/>
16:16:58: </slot>
16:16:58:</config>
does this looks correct? should i configure it differently or add anything else?
PostPosted: Thu Mar 22, 2012 9:09 pm
Folding for Elena
Folding for Elena
Don't know exactly from the logs Wiking, but there is a great Linux manual of how-to on the folding.stanford.edu page:
http://folding.stanford.edu/English/LinGuide
Hope this helps. I intend to use it tomorrow to upgrade my v6 linux to v7
PostPosted: Fri Mar 23, 2012 9:50 am
Version 7.1.52 with standard flags tends to download some huge work units.
On my Intel socket 1366, i7 950 CPU the SMP client is running a P7903 work unit. It's a little over 24% done and estimate is for it to take another 9 hours to finish. The 580GTX gets GPU WUs that are smaller: 68.35% finished and 1 hour 23 minutes to completion on a P8032 WU.
On the Intel i7 3960X CPU, socket 2011, at 30.2% - estimate 4 hours 26 minutes to finish running the same P7903 WU. The 580GTX has 31% done and will finish in 3 hours, on the same P8032 WU.
All on standard clocks but now that the weather here in L.A. is starting to cool, I think overclock is in order.
PostPosted: Fri Mar 23, 2012 1:40 pm
Glad you like it.
Please note, this is still a work in progress. A little rushed to get out along with V7 public beta. ;)
Really needs a command line install section with -dpkg for the fah packages.
PostPosted: Fri Mar 23, 2012 1:53 pm
Now that I finished working on my PC, I am going to upload my guide on how to install v7 on Ubuntu command line only.
Great guide 7im
PostPosted: Fri Mar 23, 2012 2:28 pm
Million Club - 5 Plus*
Glad you like it.
A link to the tarballs on the download page would also be nice (for those distros that use neither RPM or DEBs).
PostPosted: Fri Mar 23, 2012 9:11 pm
On my X58 board, i7 950 machine I have had troubles with the previous GPU and SMP folding clients not being uninstalled.
O should of uninstalled them myself I guess before installing the new client. Long run times might be the other service SMP running in the background. I need to start checking how many folding clients I am actually running all at the same time.
PostPosted: Tue Mar 27, 2012 2:57 pm
Glad you like it.
Not likely to get on the front page, but I'll make sure it gets on the Lin guide page.
