It is currently Tue Jun 18, 2013 9:41 pm
 Post subject: Android FAH monitoring app
PostPosted: Sun Aug 07, 2011 9:03 pm
Million Club - 10 Plus
I just installed a monitoring program on my Captivate and want to know What URLs I am supposed to use to track my clients on HFM. I am really confused and have no idea what I am doing... Anybody done this before? I am sure Ted has an android based phone and could give me some insight. If anyone else can, please feel free to post here.
 Post subject: Re: Android FAH monitoring app
PostPosted: Mon Aug 08, 2011 8:00 am
Million Club - 20 Plus
which app?
Ted
PostPosted: Mon Aug 08, 2011 8:42 am
FAHMonitor Pro
PostPosted: Mon Aug 08, 2011 10:30 am
http://breakneckapps.com/wp/category/app-releases/setup-and-support/
Ted
PostPosted: Mon Aug 08, 2011 12:59 pm
Tedster wrote:
Thanks Ted. I have that set up... But I still don't know how to get my stuff to read on my phone through the app... I have never set anything up like this before.
PostPosted: Mon Aug 08, 2011 1:25 pm
what you have to do is to set up HFM.NET to upload the xml file to a web folder using this guide that it linked to. Then, you enter the URL of the xml file that you just uploaded.
Ted
PostPosted: Mon Aug 08, 2011 1:46 pm
I must be doing something wrong... I have tried to input the URL but it says that "something went wrong, check your URL". I know I set up the thing right... But I am possibly not putting in the correct URL. What should it look like?
PostPosted: Tue Aug 09, 2011 7:07 pm
Team Member Top 100
Team Member Top 100
In HFM, I point the "Target Folder or URL" to my Dropbox folder on the local drive.
From there, it should just be loading the URL of your Dropbox on the web (including the filename) into your Android app, I think.
PostPosted: Wed Aug 10, 2011 1:04 pm
GOT IT WITH DROP BOX!!!!!! WOOHOO!!!! Thanks!
