It is currently Sun May 03, 2015 9:05 am
Post new topic Reply to topic  [ 79 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: FAH GPU Tracker V2
PostPosted: Sun May 23, 2010 5:50 pm
FAH GPU Tracker V2 is a Folding@Home Client tracking and control program that I created to make folding easier.
Features:
- Controls up to 9 clients (CPU or SMP, up to 8 GPUs)
- Tracks detailed stats for every client and every name/team combo
- Tracks WU failures by project number for each client
- Saves the logs of failed WUs
- Can automatically reconfigure user information from an XML file
- Gaming Pause feature to pause clients while gaming
- Automatically updating projects list (pulled from psummary)
- Hides all client windows to prevent taskbar clutter
- Can be minimized to system tray
- Automatic update support
- Heat Control setting to throttle GPUs based on the current WU
- Allows switching between the GPU2 and GPU3 clients (per-GPU)
- Can export an XML file with the current status of the Tracker
- Can upload the XML status file to an FTP server
- Downloads the FAH clients from Stanford on first run
- PPD monitoring of all clients including bonus points for SMP A3
Download v3.54 - Final:
FAH GPU Tracker V2
FAH GPU Tracker V2 website:
Tracker Website
FAH GPU Tracker V2 support forum:
Support Forum
Installation:
1. Extract FAH GPU Tracker V2.zip
2. Run FAH GPU Tracker V2.exe (If you have UAC enabled run it as administrator)
3. Go to Setup -> Configure
4. Change the options as you see fit
5. Hit apply and close the config page
6. You are ready to start folding!
7. Hit the start button(s) on the desired client(s) to begin folding
I am open to suggestions on how to improve the Tracker, and would be happy to add anything that seems useful.
PostPosted: Sun May 23, 2010 6:01 pm
Malware specialist
Malware specialist
Can you add a Heat Control setting for SMP WU's as well? I looked to see if there was one, but didn't find it.
I'm also not entirely certain how to operate this program. I configured it and from the looks of it, it tried to start another SMP WU?
The gaming pause feature looks awesome.
Here is the logfile:
[20:54:01] --------------------------------------------------
[20:54:02] FAH GPU Tracker v2.77 Startup
[20:54:02] --------------------------------------------------
[20:54:21] Error checking latest version
[20:55:37] Applied new config settings
[20:55:52] Starting SMP
[20:55:52] Started new WU on SMP
[20:56:09] Stopped SMP
[20:56:38] Starting SMP
[20:56:38] Resumed existing WU on SMP
[20:56:47] Stopped SMP
PostPosted: Sun May 23, 2010 6:34 pm
I can't add a Heat Control feature for SMP because the client and core don't support it. The Tracker sets the environment variable FAH_GPU_IDLE in order to reduce GPU usage, but no equivalent environment variable exists for the SMP client. If you want to reduce the heat from the SMP client the best way is to limit the number of cores it is running on. For example, on an i7 system with HT enabled (8 threads), I could set the SMP client to use 6 cores in the config. This would reduce the overall CPU load, and thus the heat produced.
Did you run install.bat? That is one of the most likely reasons for the SMP client having trouble starting. The odd part is that according to that logfile you are manually stopping the SMP client. Do you see your CPU being loaded when the client is supposedly running? If so then the client is running correctly.
PostPosted: Sun May 23, 2010 6:39 pm
Malware specialist
Malware specialist
I didn't really want it to start another WU.
Was just checking out what that feature was.
PostPosted: Sun May 23, 2010 7:02 pm
Million Club - 20 Plus
Looks nice.
Any idea on linux support, since all of my folders are currently linux?
Ted
PostPosted: Sun May 23, 2010 7:46 pm
Tedster wrote:
Looks nice.
Ted
I used VB.NET to code the Tracker, so native Linux support is not currently planned.
PostPosted: Sun May 23, 2010 8:05 pm
Ok.
Ted
PostPosted: Sun May 23, 2010 8:28 pm
Team Member Top 250
Team Member Top 250
Looks excellent, especially the games pause feature. Can't install it now, but next weekend I'll certainly give it a try. My biggest problem is always remembering to restart my clients, so if this works I'll love you forever :P
PostPosted: Sun May 23, 2010 8:52 pm
Great prog!!!
I tried to make a program with scheduling and game pausing features, but I'm lazy :) Thank You so much for this work!!!
PostPosted: Tue May 25, 2010 4:02 pm
Version 2.79 is out which includes the GPU3 client. The new GPU3 config page allows you to pick which GPUs will use the new client (all others use the GPU2 client). Note that due to the size of this update it may take several minutes, during which the Tracker will be unresponsive.
PostPosted: Mon May 31, 2010 12:04 pm
Version 2.8 BETA is out. This version will be the last beta version available for public download. Starting with this version only stable versions will be released publicly. This is to prevent a situation similar to the early 2.7x releases that had tons of bugs due to new features.
If you want to join the beta team to help with development and get access to beta versions you can apply on the FAH GPU Tracker V2 forums here:
Tracker Forums
PostPosted: Mon May 31, 2010 1:11 pm
Applied
Ted
PostPosted: Mon May 31, 2010 2:11 pm
It seems that the beta did not start my clients when I clicked the "start all" button.
Test System:
Windows xp media Center edition 2004
phenom 9950
1 gb ram (carried over)
8800 GT
k9a2 platinum
bfg 1200w psu (for when my 280's come back)
antec 900 w/ all fan slots filled
197.45 drivers
folder: C:\fah\[gpu tracker folder]
Ted
EDIT: The tracking part is working, but the start/stop client part is not on this computer
PostPosted: Mon May 31, 2010 2:26 pm
Test System:
phenom 9950
8800 GT
k9a2 platinum
197.45 drivers
Ted
Please post the contents of LOG.txt located in the Tracker's main folder. I need to see what the Tracker is doing to determine the problem.
PostPosted: Mon May 31, 2010 2:31 pm
I added comments on what I did in {}
[17:52:16] --------------------------------------------------
[17:52:16] FAH GPU Tracker v2.8 Startup
[17:54:37] Applied new config settings
[17:54:49] Starting SMP
[17:54:49] Started new WU on SMP
[17:54:49] Starting GPU 0
[17:54:49] Started new WU on GPU0
[17:58:50] Stopped SMP
[17:58:51] Stopped GPU 0
[17:59:31] Applied new config settings
[17:59:55] Starting SMP
{manually copied gpu2 executable to GPU0 folder, started, let it download a WU, and stopped it; did same with SMP client}
{clicked "start all"}
[17:59:55] Resumed existing WU on SMP
[18:00:25] Starting GPU 0
[18:00:25] Started new WU on GPU0
[18:00:39] Stopped GPU 0
[18:00:57] Starting GPU 0
[18:00:57] Resumed existing WU on GPU0
[18:01:03] Stopped GPU 0
[18:01:16] Starting GPU 0
[18:01:16] Resumed existing WU on GPU0
[18:08:40] Refreshed client status
Ted
EDIT: Also, the tracking part of it is updating still
PostPosted: Mon May 31, 2010 2:35 pm
screenshot:
Ted
PostPosted: Mon May 31, 2010 2:54 pm
Tedster wrote:
screenshot:
Ted
So if I understand this correctly the clients will run if you manually start them from the folders but not if you run them through the Tracker?
If so then this is probably the same problem another user was having with Windows Home Server. The issue in this case is the way the Tracker runs the clients hidden. It doesn't appear to affect any versions of Vista or Windows 7 but I thought it was specific to Windows Home Server.
I have a better way of running the clients hidden planned, but I have no idea when that will be done. In the mean time I will be adding a "compatibility mode" option that may resolve this issue.
PostPosted: Mon May 31, 2010 2:59 pm
That is correct. also, hitting the start and stop buttons has no impact on the progress. If by "hidden", you mean that it does not create the queue, work folder, and logfile, then it might have been working, but the WU did not progress without the clients manually started.
Ted
PostPosted: Mon May 31, 2010 4:35 pm
2.81 beta is working.
Also, I had to manually kill the GPU tracker process in task manager when I updated it.
Ted
PostPosted: Mon May 31, 2010 4:51 pm
Ted
By hidden I mean that the clients will run normally, but the console windows will not be visible. The problem with this method is that closing hidden windows safely (won't disrupt WU progress) is hard.
The method I am currently using is running the clients inside a container program. This container program waits for a close command from the Tracker then does crtl+c on itself. This closes the client safely. The problem with Windows XP is that for some unknown reason the client does not start correctly within the container.
