TWBalls wrote:
Ghostwheel wrote:
Is there a way to force your system to fold gromacs or tinkers?
I'm not sure if there's a way to 'force' it, but from what I understand, if you only use the -local flag, it should benchmark you system the first 4 WU's and give you the ones it thinks is best suited for your system.
I keep seeing the same as what the other guy said. AMD's (Namely the Athlon XP)are better at Tinkers and Intel's (and even the Athlon64/Opteron)are better at Gromacs ('cause of SSE2)
Yeah, I can't imagine what SSE2 does to F@H.
I was running a P736 Gromac when I accidentally locked up my computer (Gnome doesn't work under my new user
). So I rebooted and didn't notice the what the log said (I have it running as a process). It basicaly said that it wasn't going to use SSE because of the improper shutdown.
Because I wasn't using SSE my pph went from 6 down to 3.4
I spent 36 hours on that damn 128 pointer!
Must Check For SSE Boost OK....
Must Check For........
Dan O.
