It is currently Tue Mar 31, 2015 2:27 pm
 Post subject: opinions on a computer i may buy
PostPosted: Wed Jan 12, 2005 5:59 pm
i was wondering if any one had any suggestions for changes on a new computer i am planning to build
all the prices are from newegg
AMD Athlon 64 3500+ the newcastle version
$270
Geforce 6800GT 256 MB AGP
$388
1Gb Corsair Value Select (Dual Pack) 184 Pin 512MBx2 DDR PC-3200 2.5 Cas Latency
$140
MSI "K8T NEO2-F" VIA K8T800 Pro
$98
Hitachi 250GB 7200RPM SATA 8mb
$130
Thermaltake Xaser V Damier Black Full-Tower Case, Model "V5000A"
$ 100
Thermaltake W0014 Silent Purepower 480W 2-fan
$55
i chose to leave out a sound card and speakers because i have heard onboard audio is not that bad and i'm planning to save up for speakers
the total price w/windows and a couple other things is $1200
PostPosted: Wed Jan 12, 2005 6:50 pm
Smithfield*
Smithfield*
get the neo2 platnum with the nforce3 chipset. its worth the few extra bucks, other then that it looks great!
PostPosted: Fri Jan 14, 2005 3:40 pm
agreed
go with some better ram like this, it has better timmings(if you plan to overclock at all)
you should consider a Western Digital 10,000rpm SATA hard drive either 36GB or 74GB for your games and OS
PostPosted: Sun Jan 16, 2005 5:01 pm
well i can't really afford another HD but i am saving up for 2 15k rpm scsi HDs and a controller card
PostPosted: Fri Jan 21, 2005 2:53 pm
get memory with CL 2.0
