It is currently Mon May 20, 2013 8:29 pm
 Post subject: Comp I'm going to get soon...
PostPosted: Wed Sep 01, 2004 9:08 pm
PostPosted: Thu Sep 02, 2004 1:30 am
Smithfield*
Smithfield*
as for shopping around and free shipping and such newegg is the place to be. as for your computer its nice. nice mobo, cpu and ram combo. the only thing i'd think about changing if i was you is i'd maybe get another hard drive or a bigger one. in most cases i'd reccommend either getting a 60GB and then a 120GB or just get one big 300GB one. 80 gigs isnt a whole lot especially if your into music and movies. other then that it looks good.
PostPosted: Thu Sep 02, 2004 10:30 pm
PostPosted: Thu Sep 02, 2004 10:38 pm
Celeron
Celeron
i would recommend a 9800pro over the 5900xt just for DX9 purposes. if you dont plan on playing any DX9 games, then it your system looks good.
PostPosted: Fri Sep 03, 2004 12:03 am
Smithfield*
Smithfield*
well if thats all the storage you need for now thats cool and if you find yourself short in a few months you can always buy another hd.
PostPosted: Tue Sep 14, 2004 10:50 am
i agree with ocnoob. newegg has the msi 9800 pro for about the same price. heck of a deal. good luck with the build!
PostPosted: Tue Sep 14, 2004 1:24 pm
I bought the MSI 9800 pro recently. It shows as a 9800XT because it uses the same board as the XT. It also overclocks to XT speed.
