It is currently Sun Mar 01, 2015 4:21 pm
 Post subject: Appraisal of an H60 Cooler.
PostPosted: Mon Feb 06, 2012 10:06 am
It was once used, but my old motherboard couldn't power it up fast enough. It would always give the error that no cpu fan was detected. The original box is gone. but I have the insert and it works just fine. I have a box that is the right size laying around. I cleaned off all the thermal paste and am storing it in a clean, well ventilated area. It got it boxing day for 30 bucks. If it is worth less than that I will keep it for my next folding rig.
 Post subject: Re: Appraisal of an H60 Cooler.
PostPosted: Tue Feb 07, 2012 11:25 pm
Team Member*
Team Member*
I would say $30 bucks is a fair price though I would say $40 with the box. I know that seems bad but a $.50 box can mean a lot to some people.
PostPosted: Wed Feb 08, 2012 4:21 am
you could easily fence it for 30-40 as long as it works still. what exactly do you mean that the fan isn't detected? does it work?
PostPosted: Wed Feb 08, 2012 7:17 am
I plugged it into a extra power supply that I had laying around and it works fine. Having it wired like that in my case was not going to work however. It's good to know that I most likely will not loose money on it.
