It is currently Thu May 23, 2013 9:09 am
 Post subject: 1TB from Microcenter for $49.99
PostPosted: Tue Aug 23, 2011 6:33 am
1TB Seagate Barracuda for $49.99 instant saving. That's $10 less than newegg.
I would so buy one if laptops used 3.5" HDDs.
 Post subject: Re: 1TB from Microcenter for $49.99
PostPosted: Tue Aug 23, 2011 10:35 am
That $10 extra at newegg gets you SATA 6.0GB/s instead of SATA 3.0GB/s. Double the bandwidth for $10 is a pretty good deal.
PostPosted: Tue Aug 23, 2011 12:08 pm
Team Dino
Team Dino
vig1lant3 wrote:
Double the maximum bandwidth for $10 is a pretty good deal.
I fixed it for you.
n0b0dykn0ws
PostPosted: Tue Aug 23, 2011 12:54 pm
I assume your point is in regard to the unlikely possibility of ever reaching the bandwidth limit. Considering we're talking about a 7200RPM mechanical drive, it's a valid one to raise.
To be completely correct then, we should say double the average bandwidth, since for all intents and purposes we will never reach the maximum throughput. Mathematically speaking you can not double that which does not exist.
