It is currently Sun May 19, 2013 8:04 am
 Post subject: Appraisal on My 1st Build Parts.
PostPosted: Sun Aug 14, 2011 10:45 am
I am upgrading my first build and will have the following available:
ASUS P5Q-PRO (LGA 775)
Intel Core 2 Quad Q9550 @ 2.83GHz
8.0GB Dual-Channel DDR2 @ 400MHz 5-5-5-18
ATI Radeon HD 4870 X2 (ATI)
Since I am adding a SSD as my boot drive I may also have a 300GB WD VelociRaptor available.
Would appreciate an assessment of value on the above.
Thanks
 Post subject: Re: Appraisal on My 1st Build Parts.
PostPosted: Sun Aug 14, 2011 11:00 pm
I usually keep an eye on the going rates on ebay when trying to get a handle on what my used gear might be worth.
Motherboard....
http://cgi.ebay.com/ASUS-P5Q-Pro-775-In ... 4aadc70c86
CPU...
http://cgi.ebay.com/Intel-Core-2-Quad-Q ... 20bbe21226
Video Card....
http://cgi.ebay.com/VisionTek-ATI-Radeo ... 336a5134ac
Could use a brand name on the RAM.
VelociRaptor....
http://cgi.ebay.com/WD-WD3000HLFS-300GB ... 56458eea32
PostPosted: Fri Aug 19, 2011 1:56 pm
PM sent.
