It is currently Mon Jun 17, 2013 10:19 pm
 Post subject: I like a ballpark est.
PostPosted: Fri May 13, 2011 1:44 pm
CPU: AMD Athlon 64 X2 5400+ Socket AM2 CPU
Mobo:MSI K9N6PGM2-V V.2
RAM: OCZ Reaper 2048MB PC6400 DDR2 800MHz
DVD-RW orginal from dell
HD: WD 320G 7200RPM
Thermaltake TR2 430W
Thermaltake A4022 TR2-R1 CPU Fan
Dell dimension 3000 (would it up the value if I added a window and repaint it?)
 Post subject: Re: I like a ballpark est.
PostPosted: Fri May 13, 2011 2:02 pm
$500 ballpark, and no...unless you're a pro at it. If you are, add $50.
PostPosted: Fri May 13, 2011 2:19 pm
what if I installed a HIS H567Q1GD Radeon HD 5670 IceQ Video Card? and possibly a sound card?
PostPosted: Fri May 13, 2011 2:22 pm
forgot to mention winXP SP3 (should I sell with disc?)
PostPosted: Fri May 13, 2011 2:42 pm
$500 seems high to me for those pieces and parts, but I suppose a half blind buyer is out there. Without the OS disc, you're only going to snag $400.
PostPosted: Sun May 15, 2011 12:59 pm
Mr. Late Night
Mr. Late Night
I think $500 is way high.....especially since I was given an estimate of $250 on this:
Intel C2D E7400
4GB of OCZ DDR2-800 & 4GB of Kingston DDR2-1066 (running at DDR2-800)
Gigabyte GA-EP43-UD3L motherboard
Asus GeForce GTX260 Core 216 video card
BFG GX-550 watt modular power supply
CoolerMaster Centurion RC-514+ case
If you have an OS disc for it then I would say about $300 and even that's pushing it.
