It is currently Tue May 21, 2013 3:43 am
 Post subject: GTX 260
PostPosted: Fri Oct 01, 2010 10:03 am
Was wondering on a good craigslist price for a MSI OCV3 GTX 260 55nm/216. I have several, 6 are used, 1 still in plastic, 5 of 6 used have all the original packaging and parts. One was a open box from newegg so it has a white box :( Do you think i can get a dump on all of them or should i post them couple at a time over several weeks? Thanks for any feedback :D
 Post subject: Re: GTX 260
PostPosted: Fri Oct 01, 2010 12:33 pm
Malware specialist
Malware specialist
I would strongly recommend against dropping them all at once, otherwise people may avoid the listing thinking you are a scammer.
Depending on the person, you can probably get anywhere from $100-150 for each of them. I would start it out high.
PostPosted: Fri Oct 01, 2010 2:26 pm
cool, well i dont have to sell them instantly, they make amazing paperweights.. thanks Hack :)
