It is currently Tue Jan 27, 2015 7:16 am
 Post subject: New Forum Heading? Windows 7?
PostPosted: Wed Jan 28, 2009 3:12 pm
Has making a new Forum for Windows 7 under the existing heading "OS/Software/Programming" already been discussed?
I'm guessing the answer might be, 'if I have so much I wanted to ask / talk about Windows 7 I should find a more specific forum'. Like Microsoft TechNet Forums.
My reasoning is that I think Maximum PC users / editors think more outside the box and I want to hear feed back from them not Microsoft geeks. I see that there are three threads for Windows 7 under OS. However, it looks like my posts will just get lost in them.
Just an idea / question,
Vacendak
Gigabyte 965P DS3, E6600 @ stock, ARCTIC COOLING Freezer 7 Pro, 2GB Corsair XMS2 PC2 6400, ATI X1950 PRO 256MB, USB Logitech G15 Keyboard, Windows 7 Beta
PostPosted: Wed Jan 28, 2009 3:14 pm
just use windows parlor.
 Post subject: Forum Moderator Said Not to..
PostPosted: Wed Jan 28, 2009 7:41 pm
But...
"Things are starting to get out of hand with regards to Windows 7.
All posts about Windows 7 should be made in the appropriate pre-existing threads. (Hint: They are the stickies at the top.)
The only time you should make a new thread about Windows 7 is if you have a VERY specific PROBLEM with installing it or a piece of hardware/software that you need help fixing. Also check the existing threads to see if your problems has already been dealt with.
All new threads about Windows 7 that does not meet that criteria will be moved to the Landfill.
Have a nice day. Very Happy
Satchboy"
I'm a rookie here, didn't want to piss anyone off the first week!
Vacendak
PostPosted: Wed Jan 28, 2009 9:47 pm
Monkey Fed [PC]
Monkey Fed [PC]
If it were a full release and a finished product, I'm sure it could be incorporated in. But it IS still only a beta. There is forum help available if you need it, per Satchboy's instructions.
PostPosted: Thu Jan 29, 2009 2:57 pm
We never had one for XP or Vista so I can't really see a need for a Win7 header.
