It is currently Mon Jan 26, 2015 8:43 am
 Post subject: Website Glitch
PostPosted: Tue Jan 20, 2009 2:55 pm
On Best-of-The-Best, the budget monitor link doesn’t point to the monitor listed. This has been this way for a long time, and I want to read the review of the monitor in question. And yes, I know I could probably search and find it.
PostPosted: Tue Jan 20, 2009 3:03 pm
Monkey Fed [PC]
Monkey Fed [PC]
Click here to read your review.
PostPosted: Tue Jan 20, 2009 4:26 pm
The point is that an admin should fix the link, not that I need to see the review. That was a side note.
Thanks, though.
PostPosted: Tue Jan 20, 2009 4:32 pm
Monkey Fed [PC]
Monkey Fed [PC]
Lollerz! I just wanted to make sure you got the info you were looking for. I tried that link too, and it took me to the Samsung 206 BW from March of 2007. You indicated that you COULD search but didn't want to, so I figured I'd do it for you. It's all good in da hood.
PostPosted: Tue Jan 20, 2009 6:53 pm
... It still needs to be fixed
PostPosted: Sun Feb 15, 2009 7:50 pm
Never mind. It's better now.
