It is currently Fri Mar 27, 2015 2:55 am
 Post subject: My IE browers does not work on the forum for blondie
PostPosted: Sun Jan 09, 2005 7:26 am
Hey Blondie:
Do not know why I did not try this in my Netscape brower but I am in posting so it must be working here so I wiill try getting my other ID working so I can have a backup or delete one or the other.
Now you know it could be the browsers that is screwed up.
It is a crazy IE for sure.
I will email you here in a minute or two and let you know I am here.
David
PostPosted: Sun Jan 09, 2005 12:24 pm
Well Bondie:
I am learning that this login button has to be hit about ten times to logon using netscape browser.
Let me eplain the problem for all who read this. About tendays ago I login under dbuitt and when I Tried to post it went back to the login board. I did this about 20 or more times.
It says on here to contact the board Administration but the only problem is you can't not contact the board administrator unless you are logged in.
By the way I tried the forgot your password button and it does not work on IE either or Netscape browser either for the most part.
I downloaded the enigma to get on here and every time I logged in it said I was using the wrong name or password and that is why I have two identy on here.
I do not know what is going on but I think it is the forum and not me.
I do know how to login and put a password in.
After that I believe it is not my job to get on the forum
I do not know how long I will be login so I can post
I have a suggestion for you if you have on here to contact the board administor how about a button to do that with or a link there would be nice.
Thanks from the newbie on the forum.
David
