It is currently Mon Jan 26, 2015 1:55 pm
 Post subject: Best of the Best is Missing Something!
PostPosted: Tue Jul 08, 2008 10:19 am
I have been looking forward to the best of the best section to hit the website. Much to my dismay, it doesn't even list the best CPU to buy! I was hoping for best CPU, best budget cpu. or perhaps even AMD and Intel categories.
What gives?
PostPosted: Sat Jul 19, 2008 3:02 pm
I would add that the "Best of the Best" portion of the site is missing a date showing the last time something was added or updated.
On the other hand the new website is awesome!!!!
PostPosted: Sat Jul 19, 2008 3:49 pm
Thats another good point you brought up. Hopefully someone important views this thread and takes a look at these suggestions. :)
PostPosted: Fri Aug 29, 2008 6:56 am
Well, it's been awhile and the Best of the Best still is lacking the luster of new material and reviews for some of the parts.
PostPosted: Mon Sep 01, 2008 1:38 am
Well right now it would just be the fastest clocked Intel processor. The thing with procs, is that they are very easily OCed, so while they might say a QX9770 is the best, I can easily get the same speed with my Q9450. The CPU is a component that can change based on your budget and how much you want to overclock. I don't really see the need for it. I would however like to see the best of the sockets for motherboards broken up for different high level chipsets (X48 vs. 790i Ultra)
