It is currently Sat May 18, 2013 5:32 pm
 Post subject: Freaky Poll Results Defy Logic!
PostPosted: Wed Dec 29, 2004 8:08 am
Max [Ph]otographer
Max [Ph]otographer
Hey, I think a 4th grader could have done a better job of poll results:
Yeah, that's right kids, 10+89 = 100. :lol:
Seriously though, the actual numbers should have been 10.53% and 11.47% when rounded to two decimal places.
Why on earth did the Max PC Forums round 10.53 down to 10?
Any 4th grader can tell you that 10.50 - 10.99 should be rounded up to 11, that's just basic math.
Anyone got any ideas?
Dan O.
PostPosted: Wed Dec 29, 2004 8:14 am
Yes....you're too anal.... :?
What...couldn't take the time to point out the typo as well? :)
PostPosted: Wed Dec 29, 2004 10:17 am
Team Member Top 100
Team Member Top 100
Belboz99
I recall from writing some VB programs that VB rounds differently from pure mathematical rounding in the case of a value lying exactly between 2 values (e.g., 10.5). You can read about it for VBScripting from MSDN Library here.
In a nutshell, VBScript will return the nearest even number to the value that is to be rounded. For example, 10.5 rounds to 10 rather than 11; 11.5 rounds to 12.
If this is the case, the poll result rounded to 1 decimal place would be 10.5; applying the above algorithm would result in an integer "rounded" value of 10.
Again, this is conjecture on my part, but it may provide an explanation.
