It is currently Wed May 06, 2015 10:55 am
 Post subject: Am I the only seeing the search words in WHITE???
PostPosted: Wed Mar 01, 2006 7:49 pm
I am having a readability issue. All the search words I used appear in white in a post. It's really difficult to read. If I am not the only one, can we change the color to something like red?
Thanks!
PostPosted: Wed Mar 01, 2006 8:14 pm
Team Member*
Team Member*
Glad to see that you are using the search function.
PostPosted: Wed Mar 01, 2006 8:22 pm
I am too impatient to wait for answers. I searched if anyone has brought up this problem but found none. So I must be the only one with this problem? Anyone?
PostPosted: Wed Mar 01, 2006 8:44 pm
Team Creamsicles
Team Creamsicles
Location: Putting it all back together, and enjoying the hell out of it!
Shows up white for me, also. Never saw it as a real problem though.
 Post subject: Re: Am I the only seeing the search words in WHITE???
PostPosted: Thu Mar 02, 2006 9:40 am
Monkey Federation (Top 10)*
Thanks!
It is not techincally a bug. When you search, all the results are a different color. A quick fix is to highlight everything with your mouse so you can see the text.
PostPosted: Thu Mar 02, 2006 3:42 pm
What's all this fuss about a "search" option? Never heard of it....
PostPosted: Tue Apr 25, 2006 6:15 pm
Location: Playing Chicken with the Train at the River. Party Time!!
Thanks!
It's taken me awhile but I think I have it figured out.
When you copy/paste the url of the search result link, remove the words searched for after the 'highlight='.
Ex:
http://www.maximumpc.com/forums/viewtopic.php?p=394230&highlight=appear+white#394230
Gives you this.
Note: The words Appear and White are highlighted.
Remove the search words, 'appear+white':
http://www.maximumpc.com/forums/viewtopic.php?p=394230&highlight=#394230
You get this.
Note: No highlights.
