It is currently Wed Apr 01, 2015 9:05 am
 Post subject: Request for a thread preview function.
PostPosted: Mon Aug 08, 2005 9:38 am
It's a nice feature, lots of ofther bulletin boards have it.
Here's the code for it:
## MOD Title: display first message as title
## MOD Author: emrag < emrah987@hotmail.com > (Emrah Türkmen)  www.canver.net
## MOD Description: with this hack when you hover the mouse on topic link you
##          will see first message as title like vBulletin Boards ;)
## MOD Version: 1.0.2
## Installation Level: Easy
## Installation Time : ~3 minutes
## Files to Edit: viewforum.php
##        templates/subsilver/viewforum_body.tpl
## Included Files: n/a
## Author Note: -
## MOD History: 25.09.2004 - 1.0.0
##      - First release
##      07.10.2004 - 1.0.1
##      - Fixed a bug - thanx to Clock
##      25.11.2004 - 1.0.2
##      - added a character limit for hover title - you can change this value ;)
##      (before if message is too long hover title won't be display. Now fixed)
##      - EasyMod compitable
## Before Adding This Hack To Your Forum, You Should Back Up All Files Related To This Hack
#-----[ OPEN ]------------------------------------------
viewforum.php
#----[ FIND ]------------------------------------------
      $row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
      $row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
#-----[ AFTER, ADD ]------------------------------------------
// display first message as title by emrag ;)
      $chr_limit = '1000'; // character limit for hover title
      $sql = "SELECT p.*,  pt.post_text, pt.post_id
         FROM " . POSTS_TABLE . " p, " . POSTS_TEXT_TABLE . " pt
         WHERE p.topic_id = $topic_id
            AND pt.post_id = p.post_id
         ORDER BY p.post_time
         LIMIT 1";
      if ( !($result = $db->sql_query($sql)) )
         message_die(GENERAL_ERROR, 'Could not obtain topic information', '', __LINE__, __FILE__, $sql);
      $row = $db->sql_fetchrow($result);
      $first_post = $row['post_text'];
      $first_post = str_replace('"', "''", $first_post);
      if (strlen($first_post) > $chr_limit)
         $first_post = substr($first_post, 0, $chr_limit);
         $first_post .= '.......';
         'TOPIC_FOLDER_IMG' => $folder_image,
         'TOPIC_AUTHOR' => $topic_author,
#-----[ BEFORE, ADD ]------------------------------------------
         'FIRST_POST' => $first_post,
<a href="{topicrow.U_VIEW_TOPIC}" class="topictitle"
#----[ AFTER ADD ]------------------------------------------
title="{topicrow.FIRST_POST}"
#-----[ SAVE ALL FILES/CLOSE ]------------------------------------------
# EoM
8)
PostPosted: Mon Aug 08, 2005 10:55 am
iron colbinator
iron colbinator
Can you give us an example of what it'd look like (or a link)?
PostPosted: Mon Aug 08, 2005 11:38 am
http://www.howardforums.com/forumdispla ... 77ccf&f=39
Just mouseover the thread titles. :)
I'm pretty sure they are using vBB3, but the concept is the same. Let me do some digging to find a phpBB board that has it implemented. :)
PostPosted: Mon Aug 08, 2005 2:54 pm
Here is a phpBB message board: http://kansas.no-ip.com/folding/viewfor ... e36fdec12c
The only difference is that one shows the last post, not the first, but the idea is the same. :)
PostPosted: Mon Aug 08, 2005 4:34 pm
It would be nice to preview the first post...
PostPosted: Wed Aug 10, 2005 7:58 am
that's pretty nifty. I'd make browsing the new threads much easier and faster.
PostPosted: Wed Aug 10, 2005 12:35 pm
Monkey Federation (Top 10)*
I think that's el lame-o.
So you get to see the first 50 characters. WHOOPITY DO.
Click the link, if you don't like the feature, then use the Backspace button.
PostPosted: Wed Aug 10, 2005 1:01 pm
well itd be nice for dialup users at the very least. i like it, using it i dont have to load the thread/page just to find out a bit more info. just mouse over.
PostPosted: Wed Aug 10, 2005 6:01 pm
You can edit the hack to change the amount you see. ;)
PostPosted: Wed Aug 10, 2005 9:04 pm
Maximum PC Editor
Maximum PC Editor
Those types of plugins work reasonably well on low-traffic forums. Adding the stuff to make that work could make the forum painfully slow, especially for modem-based visitors. I'd prefer to keep the site lean and mean.
Besides, that kind of preview functionality discourages people from making concise thread titles. I like people to name their threads in such a way that everyone will know what the topic is, and whether they want to look at it or not.
///Will
