It is currently Mon Apr 27, 2015 7:00 pm
 Post subject: links in posts
PostPosted: Mon Jul 22, 2013 6:22 pm
what is up with the automatic links in posts that have nothing to do with the post, they suck. they are no better than spam.
 Post subject: Re: links in posts
PostPosted: Mon Jul 22, 2013 9:35 pm
Because a combination of characters is enough for the parser to believe you were typing in a URL.
Just fix your typing. ;3
Unless you mean sponsored posts, then I don't see them.
PostPosted: Tue Jul 23, 2013 9:19 am
I see two in your answering post, parser turned into one, and post subject another. one disappeared after I posted, and answering turned into one in this one as well as one in the subject line.
PostPosted: Fri Aug 02, 2013 8:16 am
I have no idea what you're talking about. I don't see any links in any posts.
Can you post a screen grab to show me? Sounds funky.
PostPosted: Fri Aug 02, 2013 9:16 am
actually, every one of the dam things has disappeared, perhaps future did some maintenance.
PostPosted: Sun Aug 04, 2013 9:06 am
Welp, that works, then.
PostPosted: Thu Aug 29, 2013 2:16 pm
Monkey Federation (Top 10)*
Someone needs to scan for malware.. lol
