It is currently Sat Jan 31, 2015 1:13 am
 Post subject: strange problem
PostPosted: Mon May 02, 2005 8:43 pm
i'm having a strange problem. i read a thread go back to the main folder and the thread still appears unread. this has been going on for several weeks now. any ideas?
PostPosted: Tue May 03, 2005 5:44 am
same for me, and i cant set the auto log in check box i have to log in manually every time.
PostPosted: Tue May 03, 2005 7:24 am
Monkey Federation (Top 10)*
Eat your cookies and throw away your temp files. :P
But seriously, I'm having the same problem on a sister forum. :(
PostPosted: Tue May 03, 2005 1:10 pm
This has been discussed in a couple threads, its been going on for months now. What SM said worked for me, kill the cookies and temp files in the Temporary Internet Folder.
PostPosted: Tue May 03, 2005 4:25 pm
didn't work for me :(
PostPosted: Tue May 03, 2005 5:53 pm
Or was that the bug where you couldn't sign in automatically? Either way, its fixed for me now. Yeah, I think thats the right thing. Just make sure the two MPC cookies are dead.
PostPosted: Wed May 04, 2005 7:15 am
deleting cookies worked for me, for the sign in anyway
PostPosted: Sun May 08, 2005 10:21 am
i'm still having the problem. and its the only forum where it happens
PostPosted: Sun May 15, 2005 4:39 pm
are you pressing the back button? if you you are, then it won't work
