It is currently Tue Apr 28, 2015 8:29 am
 Post subject: Ads on MPC main page
PostPosted: Sat Mar 05, 2005 2:57 am
Folding Momerator
Folding Momerator
Was checking on the main MPC website page, and noticed that the Monarch link adds a line for AFFIL=MPC & the product finder gives a price grabber search in an MPC page. Does MPC get any kick-backs when using the links from the main site? I'm curious, because if you do, I will start using links from there in posts when suggesting parts, etc.
Every little bit helps :wink:
*edit- I typed out mag page- it should have read website.
PostPosted: Sat Mar 05, 2005 4:52 am
I imagine at the bare minimum, it's a way for the vendor to keep track of ad clicks, which no doubt helps sells the ads.
Thanks Blondie :)
-Six
PostPosted: Sat Mar 05, 2005 4:56 am
Folding Momerator
Folding Momerator
Thanks Blondie :)
-Six
Well if it will help, I will use it :D Hope others do too.
