It is currently Sun May 19, 2013 12:21 pm
 Post subject: new posts stay new
PostPosted: Fri Aug 27, 2010 11:34 am
Million Club 5+ [PC]*
since the change over unread topics keep their unread logo indefinitely, before they would revert after a week or so of inactivity. would it be possible to re-implement that feature? otherwise every board will always say their are new topics unless you view every single thread in a section
also, where is the "mark all posts as read" button? do we still have one? I tried the delete all board cookies option at the bottom and it didn't work.
I even tried setting the forum to only display threads that have been active in the last week, but the section still says there are new posts even though it doesn't display them
 Post subject: Re: new posts stay new
PostPosted: Fri Aug 27, 2010 12:28 pm
Topics stay new until you read them where before they showed only those posts that are new since the last time you logged in. I think.
The 'Mark all posts read' button is found above the right-most column in the folder view.
PostPosted: Fri Aug 27, 2010 6:55 pm
thanks, not sure how I missed it.
still miss the old behavior though
oh well
PostPosted: Sun Sep 19, 2010 7:48 pm
Hi,
My name is camellia from australia.
I wonder where i can post my introduction or i don't need to post introduction?
Hope i have some help.
thanks a lot.
Open Source Development
PostPosted: Mon Sep 20, 2010 5:07 am
You can right click the mark all posts read link and create a bookmark in firefox from the link. Put the bookmark on the bookmark toolbar next to the maxpc bookmark (or the porns r 4 us button if you prefer). You can mark all posts read with a simple click on the bookmark shortcut. Doesn't matter what forum you are in, you don't have to return to the index. Shouldn't have to do that since every other site I've been to lets you mark all posts read from any page. At least it's now possible to mark all posts read. Used to be you could click to mark them read, then check a few minutes later and find threads whose latest posts were from weeks earlier.
