It is currently Fri Apr 24, 2015 8:31 pm
 Post subject: Forced??? Manual MPC Log In
PostPosted: Sun Jan 23, 2011 3:10 pm
When I use RoboForm to automatically go to and log into MPC it won't do it since this latest change. I have to manually click on "Log In" on the main page. Which then brings up a new log in screen for me to then manually enter the info. I always use RoboForm for logging in since I always use 10+ character passwords that are different for each place I log into.
There is no problem with the forums.
PS; except for the log in problem I like the changes so far.
 Post subject: Re: Forced??? Manual MPC Log In
PostPosted: Tue Jan 25, 2011 10:41 am
Anyone on the staff (assuming you folks are watching this forum to see how the new changes are doing) care to comment. Any help from the moderators/admin types would be appreciated.
I have tried everything I can think of to get RoboForm to at least recognize the log in screen so I can click on fill and submit. Again since I use strong passwords for each site there is no possible way for me to remember each and every one. It is also a real PITA, at least to me, to have to manually log in each time. I also never elect to have sites remember my log in info. I mean one of the main purposes of a good password manager is to be able to do one click log in's, right?
I see some hints in related threads that you folks may also be revamping the the forums. Hopefully you aren't going to do the same thing with the log in that you did with the main site.
PostPosted: Sat Jan 29, 2011 2:31 pm
Bump
Note I do this under duress. I would like an answer.
