It is currently Wed Jun 19, 2013 12:20 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Private Messages Email Notify
PostPosted: Mon Aug 16, 2010 5:18 am
I got 1 new private message, but the forums sent me 20 emails over a course of 4 hours notifying me that I have the same new message. Is there a way of fixing this short of disabling email notifications?
 Post subject: Re: Private Messages Email Notify
PostPosted: Mon Aug 16, 2010 5:27 am
OK, I'm getting this thing even after I've checked the private message. I'll disable it for now until a fix is found.
PostPosted: Mon Aug 16, 2010 6:07 am
Million Club - 20 Plus
I just got 50+ notifications for 2 new PM's
Ted
PostPosted: Mon Aug 16, 2010 7:40 am
Still getting emails after disabling notifications in settings.
PostPosted: Mon Aug 16, 2010 8:27 am
We are aware of this and have notified the ones capable of fixing it.
For now try going to your User Control Panel>Board preferences>Edit global settings and then select NO for email notifications and then submit.
Exit out of there and then go back in and select YES.
Let me know if that works or not. Doing this for thread subscriptions seems to work.
PostPosted: Wed Aug 18, 2010 9:42 pm
Team Member Top 250
Team Member Top 250
I have received 25+ emails in the past 24 hours for only two threads, each with one new post.
I tried disabling and re-enabling email notifications, but it does not work.
Is there something else I can try?
PostPosted: Thu Aug 19, 2010 7:56 am
Monkey Federation (Top 10)*
Try deleting the emails.
PostPosted: Thu Aug 19, 2010 8:03 am
I'm still waiting for a reply from the tech guys so I have nothing for you to try right now.
PostPosted: Thu Aug 19, 2010 8:22 am
Team Member Top 250
Team Member Top 250
And what do you hope that will accomplish? :? hmmmmm?
P.S. I already did :)
PostPosted: Thu Aug 19, 2010 8:52 am
Malware specialist
Malware specialist
Perhaps if you guys are using Gmail you can create a filter to auto-delete (or just archive them) all of the e-mail notifications (will require a change in e-mail which you should be able to, I think).
This would require Gmail, but may be a workaround for some that do not like all of the e-mail notifications.
PostPosted: Thu Aug 19, 2010 9:26 am
Actually Gmail bundles emails from the same source into one listing and you can expand to see the subsequent items.
So this would eliminate the clutter even if you still receive multiple emails.
PostPosted: Thu Aug 19, 2010 9:47 am
You can create 'rules' in Outlook, too bro.
 Post subject: "Views" are being treated as replies.
PostPosted: Tue Aug 31, 2010 3:09 am
I believe what is happening is, every time someone "views" a thread. the software sees that as a 'reply' and treats it as such.
I have three threads and one returned only a few e-mail notifications, where as the others bomb me with dozens.
BTW, the title of this thread is incorrect. It has nothing to do with "Private Messages" which is why I didn't see it when I posted my thread.
 Post subject: Re: "Views" are being treated as replies.
PostPosted: Tue Aug 31, 2010 6:49 am
It started out talking about PM's, but then shifted to threads
Ted
PostPosted: Sat Sep 04, 2010 4:39 pm
Then back to both then...
MPC is in my spam box. 212 unread messages from MPC and my console is set to not send me emails. I use to get none with this setting in the forums unless I've been a bad boy. I've also refreshed and have 75 unread PM's which I in fact have read all but 4. I'm in ever section of the forums and every time someone replies I get an email. Same with PM's. I'm running blind here dudes...
Even in the forum itself, I can have 75 unread PM's, read 71 of them, and there's still 75 unread. I've read them. I've seen them. Perhaps this has to do with the other topic I just started about knowing what thread is read and is not read. MPC/Forums is running blind too?
PostPosted: Sat Sep 04, 2010 5:41 pm
I'm sorry, but how long does it take to fix this simple bug? 3 weeks since this topic started, still nothing changed. Every 10-15 minutes receiving email about topic that got one reply. Obviously its the same bug affecting PM notifications and topic subscriptions.
You are loosing reputation at least in my eyes, soon you'll be referring to as minimumPC...(note the lower case) :lol:
/me made sure topic subscription is not selected before submitting this one :)
P.S.
This topic shifted to thread subscription, because other similar topics being locked with a link to this topic.
PostPosted: Tue Sep 28, 2010 10:28 am
Maximum PC Editor
Maximum PC Editor
Is anyone still having this problem?
PostPosted: Tue Sep 28, 2010 10:39 am
Team Creamsicles
Team Creamsicles
No sir, not since that first time like the OP
PostPosted: Tue Sep 28, 2010 11:07 am
Team Member Top 250
Team Member Top 250
I did not have the problem when you posted, I only received one notification.
Same goes for when mark_b_smith_II posted, one notification and that's it
It is fixed for me :D
