It is currently Thu Jun 20, 2013 2:18 am
 Post subject: Difference between AGP 8x and AGP Pro
PostPosted: Fri Aug 27, 2004 10:11 am
I might be a little confused on this matter. Is there such a thing as an AGP Pro slot, or is it a specification just for the card. If it is on the motherboard, could and AGP 8x slot support and AGP Pro rated card and vice versa? :?:
 Post subject: Re: Difference between AGP 8x and AGP Pro
PostPosted: Fri Aug 27, 2004 10:12 am
i believe the AGP Pro slots are for the workstation cards, like Fire GL and Quattro.
PostPosted: Fri Aug 27, 2004 11:03 am
AGP Pro for AGP Pro cards.
AGP 8x for AGP 8x cards.
Not all boards with AGP 8x support AGP Pro, IIRC.. but unless you want a workstation card, don't bother looking for the AGP Pro spec.
PostPosted: Fri Aug 27, 2004 11:04 am
Thanks!
