It is currently Wed May 22, 2013 7:09 am
 Post subject: How do I verify that new Video Card is fully functional ?
PostPosted: Fri Oct 21, 2011 9:41 pm
I bought three ATI FirePro 2460 Video cards each with 4 mini DP ports supporting 4 Monitors.
Right now I have only two monitors & others will take little time to arrive.
Meanwhile I have to check these video cards to see if they are fully functional & there is no damage or other problems with them & let the seller on ebay know about them.
Can I just plug 2 monitors in 2 ports & then switch to other 2 ports to check if they are working ?
So question is if checking each card with 2 monitors at a time instead of all 4 monitors in 4 ports would prove that the video card is fully functional ?
Thank You
 Post subject: Re: How do I verify that new Video Card is fully functional
PostPosted: Sat Oct 22, 2011 9:56 am
Yes.
PostPosted: Mon Oct 24, 2011 7:11 pm
noghiri_x wrote:
Yes.
Thank You.
