It is currently Tue May 21, 2013 4:15 pm
 Post subject: What videocard does Borderlands require for the pc?
PostPosted: Tue Oct 18, 2011 7:51 pm
I would rather get it for the pc, but when i got l4d2 it was too new and couldn't use my videocard (I have the nvidia 6800 and l4d2 needs the nvidia 7600). Would i be able to play borderlands?
 Post subject: Re: What videocard does Borderlands require for the pc?
PostPosted: Wed Oct 19, 2011 8:34 am
most likely not, it needs an 8600gs minimum.
PostPosted: Wed Oct 19, 2011 9:17 am
what's ur current system specs? Can you upgrade/have a budget? What resolution you plan on playing at?
If you have a console, get it on that instead. It'll play much much better than the video card you have now.
