It is currently Wed Jun 19, 2013 12:47 am
 Post subject: Will I notice much of a difference? 2 gtx580 vs 3.
PostPosted: Fri Jun 17, 2011 9:18 pm
Here are my specs.
asus rampage 3 extreme
17 950 running at 3.7
12gb running at 1291
1200 watt corsair
2 gtx 580 sli
3 lg 27" running at 5924x1080.
Frame rates seem fine and not sure what I am getting but run v sync most of the time. So will I actually see much of a difference in my games. Play mostly fps like bad company 2, black ops, crysis 2.
 Post subject: Re: Will I notice much of a difference? 2 gtx580 vs 3.
PostPosted: Fri Jun 17, 2011 10:44 pm
chef7734 wrote:
Here are my specs.
1200 watt corsair
2 gtx 580 sli
The human eye can only perceive 60 frames a second, so unless you're super human, probably not.
PostPosted: Sun Jun 19, 2011 3:54 pm
Yes and no. The extra card will give you more FPS in some games, others not so much. There have been alot of reviews where 3 GPU's can actually degrade performance and get you less FPS. Do a search for 6990+6970 vs SLI 580 and you'll see what I'm talkin about.
The 3gb 580's might help you out because of the higher ram amount for that huge resolution.
PostPosted: Sat Jun 25, 2011 1:09 pm
All the articles I read say don't bother, the small gain isn't worth the money spent.
PostPosted: Mon Jul 11, 2011 6:46 pm
There are some games/settings where the the extra VRAM would come in handy, but 1.5GB is good for most games up to 5760X1080 4X16X. I've been switching back and forth between a GTX590 and 2GB GTX560Ti SLi for this resolution.
As for the OP, the scaling on a third GTX580 will be much lower than on two, around another 30%. I personally don't think a third 1.5GB GX580 is your best upgrade path given your high resolution. I'd go 3 X 2.5GB GTX570 if you're looking to stay with NVIDIA and surround.
