It is currently Sun May 19, 2013 1:55 am
 Post subject: Will I have enough power?
PostPosted: Tue Jun 07, 2011 10:27 am
I'm looking at getting this video card.
http://www.newegg.com/Product/Product.a ... 6814130595
GTX570 EVGA SuperClocked
My question is will my current PSU be enough to power it? I'm running a Corsair 750TX
The minimum requirement is 550 watt or greater power supply with a minimum of 38 amps on the +12 volt rail.
Current Rig:
Intel Core i7 930
6GB RAM
2 Hard Drives
ASUS Mobo (Forgot model)
Thank you!!
 Post subject: Re: Will I have enough power?
PostPosted: Tue Jun 07, 2011 10:44 am
Hello again.
I think that will be sufficient, unless you have extra peripherals not listed or a bunch of fans or something. I run 2 GTX 260s on an 850W with no problem.
PostPosted: Tue Jun 07, 2011 11:00 am
Ok, cool! I'm running 3 20mm fans & 1 DVD drive. But yea I think I should be ok.
PostPosted: Tue Jun 07, 2011 3:09 pm
You will be fine, even if you're CPU is OC'ed. Now if you want to run SLI you will need at min a 850w PSU.
