It is currently Fri May 24, 2013 8:18 am
 Post subject: Differing clock speeds on each of the ATI 4870x2's gpu's?
PostPosted: Sat Mar 26, 2011 7:47 pm
I have an ATI 4870x2, one of the double-decker videocards. I noticed recently that the clock speeds on one of the GPU's is set to 750MHz (gpu) and 900MHz (mem), but the second GPU is only set to 507MHz (gpu) and 500MHz (mem). The temperatures are obviously quite different between the two GPU's as well. Are these values suppose to be different speeds, or should I change the second set to match the first? Could this cause any issues? The first gpu typically runs around 75-80c, even when not gaming. But, it never goes about 85c, even under heavy load.
 Post subject: Re: Differing clock speeds on each of the ATI 4870x2's gpu's
PostPosted: Sun Mar 27, 2011 7:54 am
Million Club [PC]
Million Club [PC]
Have you checked clocks at idle and load? Under load, both should go up to 750/900, and at idle the second should stay at 500/500 and the first at 600/500.
PostPosted: Sun Mar 27, 2011 9:58 am
Using GPU-z it never shows the second gpu never having a load at all, forgot to mention that earlier. Which is weird, because crossfire is shown to be enabled. Could that be why the second card never has a load, because the system treats it like one card? And the first gpu, the clock speeds always remain at 750/900, they never go down. I posted this along with the first part of my question on another forum hoping to get some answers a little quicker. It's an issue I've had for quite a while with rendering water on this card: http://www.youtube.com/watch?v=_UKK5OvrsKI
PostPosted: Mon May 02, 2011 3:58 pm
Are you using the "bridge connector" between the two cards...if not that is your problem.
