It is currently Wed May 22, 2013 10:21 pm
 Post subject: 8 Pin Plug on my ATI card... why didn't you guys tell me!
PostPosted: Sat Jan 08, 2011 7:08 am
So I bought an ASUS EAH5850. It has two power connections on the card. One six pin and one eight pin.
I got lots of six pin connections from my PSU but I didn't see an 8 pin plug. I went to the local Fry's Electronics to pick one up.
After two visits to the electronic store I realized that this eight pin connection is really a 6 + 2 pin plug!
Begin flame now...
 Post subject: Re: 8 Pin Plug on my ATI card... why didn't you guys tell m
PostPosted: Sat Jan 08, 2011 9:49 am
well, its nice that PSU makers make a 6+2 pin power connector - so far i have not been in need of the +2 pins, but it's always nice to know they are there, since i do not replace power supplies often. also, since the +2 is usually connected to the cable as in the picture, seems like it would be obvious that it is an 8-pin, as well.
was the power supply box misleading by saying it had only 6-pin connectors?
PostPosted: Sat Jan 08, 2011 10:12 am
No, the PSU was not misleading I just failed to add 6 + 2 to get 8.
I asked myself during the process, "Hey, I wonder what those 6 + 2 plugs do?"
Then I would turn to the 8 pin plug and say, "Where am I going to get an 8 pin plug?"
Finally I went to the electronic store and found an adapter labeled "8 pin". The adapter had the same 6 + 2 config. I felt pretty dumb and walked away... Knowing I had the proper plug the entire time!
