It is currently Wed Jun 19, 2013 1:28 am
 Post subject: Mobile GeForce GTS 360 with GDDR5
PostPosted: Sat Jul 24, 2010 2:19 am
Until I can afford a custom-built laptop, I was considering buying a mid-range ASUS to tide me over. Is the GeForce GTS 360M good enough to play games at high to ultra-high at 1080p? Or will I have to dial down the graphics settings or resolution in order to get playable frame rates on it. I've never used an Nvidia card before, so any information on the card's capabilities will be greatly appreciated.
PostPosted: Sat Jul 24, 2010 10:51 am
Million Club [PC]
Million Club [PC]
What games? Generally you'll be limited to middling settings on new games with a GTS 360M at 1080p.
PostPosted: Sat Jul 24, 2010 4:12 pm
I was thinking of more graphically intensive games like Fallout 3 and Far Cry 2.
PostPosted: Sat Jul 24, 2010 5:49 pm
You can run it at 1080p but for intensive game, maybe medium-high for good performance.
PostPosted: Sat Jul 24, 2010 9:14 pm
Would it be worth getting a 15-inch with that GPU? Or buy a 17-inch with a 5870 and suck it up with the extra weight?
PostPosted: Sun Jul 25, 2010 6:16 pm
Celeron
Celeron
Depends if you go places with it, but a 15-inch gaming laptop is not going to be light either. It's really about the size - a 17-inch gaming laptop can be overwhelming.
PostPosted: Sun Jul 25, 2010 7:24 pm
I'd be taking it to school with me every day and to my grandparents' house when I go.
PostPosted: Sun Jul 25, 2010 8:16 pm
Million Club [PC]
Million Club [PC]
no way then. Taking a 15" laptop to school is enough of a chore. I did that for 3 years, and I wish I could have replaced it with my M11x way before I did.
If you're going to take it to school, I think you'd be best off going with an HP Envy 14. Its plenty fast for games at its 1600x900 resolution, and is far more portable than bigger laptops. Its well worth not being able to play at the very highest detail levels.
Have you also considered building a desktop and getting a budget gaming laptop? For $1000, you can build a desktop thats far faster at games than the highest-end $5000 laptops, and then get a cheap $700 gaming laptop just for mobility. Desktops also last longer, because you can't really upgrade laptops.
PostPosted: Sun Jul 25, 2010 8:21 pm
Is the Envy 14 a quad-core?
PostPosted: Sun Jul 25, 2010 8:54 pm
I need a quad-core laptop because I'll be using it for a video editing class in school.
