It is currently Mon Jan 26, 2015 10:39 pm
 Post subject: Noob router question
PostPosted: Mon Jan 17, 2005 6:25 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
On the back of rounters what is the COM port for?
PostPosted: Mon Jan 17, 2005 6:47 pm
Your mouse :)
Are you sure that's a com port you're looking at??
PostPosted: Tue Jan 18, 2005 5:19 am
7yrs+11,000 Posts
7yrs+11,000 Posts
yeah, COM it looks like a monitor input.
PostPosted: Tue Jan 18, 2005 7:43 am
Its prolly a serial connection for console access...
or...
some routers include a comm port for dial access for backup in the event of a failure on the primary link
 Post subject: Re: Noob router question
PostPosted: Sun Jan 23, 2005 9:31 am
You can access the router using ethernet (192.168.0.1 or whatever address)... or use your PCs serial port via the COM port on the router. Sometimes the COM port gives access to configuration options that are not available to the ethernet based interface. As mentioned in another post, it usually allows you to access the router if ethernet access crashes. And, it is used to upgrade the router firmware.
