It is currently Thu Jan 29, 2015 1:19 pm
 Post subject: Best wireless G Channel
PostPosted: Sun Jan 16, 2005 3:12 pm
i'm setting up my wireless network to share internet access for my 2 PCs and my xbox in the living room. Living in an apartment complex, i want to be sure to set it up to have it secure as possible and still have the best connection. I know the the most commonly used wireless channel is 6 so i won't use it, but is there any other particular channel that might be consider the least common, and also is there any advantage in the area of range to using different channels, since they work on different frequencies?
PostPosted: Sun Jan 16, 2005 5:36 pm
Celeron
Celeron
The recommended channels are 1, 6, and 11. It ultimately depends on your situation. Try channels 1 and 11 first, and then try all the other channels. See which one gives you the least troubles and stick with it.
By the way, I'm running on channel 11.
