It is currently Sun Apr 26, 2015 8:22 am
 Post subject: How do I run a dedicated CS:S server behind a router?
PostPosted: Fri Jan 14, 2005 4:31 pm
I know a little bit about port forwarding.
However, how do I get the game display my WAN ip address instead of my local ip? Thanks.
PostPosted: Fri Jan 14, 2005 5:44 pm
Go here to find out your IP: http://checkip.dyndns.org/
PostPosted: Fri Jan 14, 2005 6:10 pm
Yep, I am see my ip there, but what do I need to do?
PostPosted: Fri Jan 14, 2005 8:30 pm
What kind of router do you have?
Regardless, you have to allow via your firewall in your router the following ports:
UDP 1200 (used for friends service)
UDP 27000 to 27015 inclusive
TCP 27020 to 27050 inclusive
And for Counter Strike Source you need to setup a virtual server, and allow ports:
27015
and
27016
all udp (user datagram protocol).
PostPosted: Fri Jan 14, 2005 8:41 pm
No Hope = No Fear
No Hope = No Fear
now that your past the router, here is the server info you will need...
SRCDS
PostPosted: Sun Jan 16, 2005 8:11 pm
Thank you very much guys.
Ok, I seems to know how to foward the ports. (I have a linksys WRT54GS router) However, I can't seems to find my own server through the CS:S find server screen because my server computer uses the local ip address (192.168.1.105) instead???
How do you make CS:S use the internet ip address instead? Thanks.
PostPosted: Sun Jan 16, 2005 8:49 pm
No Hope = No Fear
No Hope = No Fear
it will always show the local address as is mine too...
22:47:50 hostname: fy_houses 24/7
version : 47/1.1.2.5 2834 secure
tcp/ip : 192.168.123.139:27016
map : fy_houses at: 0 x, 0 y, 0 z
players : 6 active (9 max)
but it also shows up online as well...
chk with www.gametiger.com and search for your WAN ip address...
PostPosted: Sun Jan 16, 2005 9:10 pm
Do I "have to" disable DHCP to get it to work? Thanks a lot!
PostPosted: Sun Jan 16, 2005 9:53 pm
No Hope = No Fear
No Hope = No Fear
No u don't have to disable DHCP... :?
