It is currently Tue Apr 21, 2015 2:12 am
 Post subject: Shotgunning with dual gigabit lan
PostPosted: Thu Jan 13, 2005 9:02 pm
Remeber when you could use two modems to double your bandwidth. I think it was called shotgunning. Is it possible to do the same with a dual gigabit lan borad?
PostPosted: Fri Jan 14, 2005 9:49 am
Maybe these links will help
http://www.dslreports.com/forum/remark, ... ~mode=flat
http://www.xincom.com/
PostPosted: Fri Jan 14, 2005 9:32 pm
Thanks chris 8)
 Post subject: Re: Shotgunning with dual gigabit lan
PostPosted: Sun Jan 16, 2005 5:02 am
I thought it was called Multilink PPP?
:wink:
I haven't gone in and read the info on the links that Chris posted yet....However, back-in-the-day with Multilink PPP the users connection had to terminate both dial calls on the same chasis in order for the calls to bind...it also had to be supported s/w wise at the chasis as well.
Without a routing protocol between the provider and you to facilitate bandwidth sharing I don't believe this can be done at layer3.
...and I'm pretty sure you can't do it with two different providers...
PostPosted: Sun Jan 16, 2005 5:49 am
check that link
PostPosted: Sun Jan 16, 2005 8:44 am
Minky wrote:
check that link
Hmmmm. yea. Couldn't find any white papers or anything that explains how it is done.
looks pretty cool, I guess...I'm still skeptical.
Side note. your fastest speeds are limited by the smallest connection that the data is traversing.
I currently get 3Mbps on my cable connection...and as I would like more more more like most people...I don't really see it as economically viable. My speeds are fast enough in most cases where I rarely find myself saying "I wish I had more bandwidth" (except upstream of course). The benefit would be for BIG downloads, which are infrequent for me...
not to mention DOUBLE the cost.
PostPosted: Sun Jan 16, 2005 9:11 am
Smithfield*
Smithfield*
the real use for this reliability. if i hosted my own sites in my house i'd buy that router and put a dsl and cable connection on it. that way if one fails the other one is instantly used and i have 0 downtime.
PostPosted: Mon Jan 17, 2005 9:51 am
That makes sense.
PostPosted: Sat Jan 22, 2005 5:24 am
It's reasonable, reliable, and if you set it up to shotgun the two connections, it's damn fast. I've owned the Xincom DPG-402 and DPG-502, and they were great routers.
Note that the 402 only has 10Mbps WAN ports.
PostPosted: Sat Jan 22, 2005 11:44 am
Smithfield*
Smithfield*
if you have a good router with good load balancing it really will feel like you have two cable or DSL or t1 connections. if you get a cheaper one you'll get something like 150% the bandwith. of the connection your doubling up.
