It is currently Fri Mar 06, 2015 5:00 pm
 Post subject: sharing dsl with a pc and mac please help?
PostPosted: Tue Jan 11, 2005 1:27 pm
Ok guys im definitely not a networking guru here but im having such a hard time getting my girlfriends mac to share our DSL connection. I have a linksys router hooked up and the mac can see the router. I've even got into the linksys firmware from the mac but still no web access...please share your knowledge..
PostPosted: Tue Jan 11, 2005 2:03 pm
King of All Voodoo2 Cards
Need more info.
Which Linksys Router did you get?
What version of MacOS is her Mac running?
How is the Mac connecting to the Router? (Wire or Wireless?)
PostPosted: Tue Jan 11, 2005 2:10 pm
not sure the model of the linksys but its the very common one. believe she got it at a radio shack. its hard wired with a new 25 foot cat 5 cable. and its running mac os 10. one of them bubbly imac's.
PostPosted: Tue Jan 11, 2005 3:00 pm
Ok, click on the happy apple icon on your gf's Mac, scroll down to system preferences and hit that, then double click on the Network icon, and when that loads up click on Built In Ethernet and tell me what it says on that screen.
PostPosted: Wed Jan 12, 2005 11:25 am
looks like she has it set on Ppoe with her username and password. it recognizes the ip address and under the etenet tab its set up on automatic. ohh and the router model number is the BEFSR41.
PostPosted: Wed Jan 12, 2005 12:44 pm
If your DSL is the PPPoE type, remove the PPPoE username and password from the Mac and add that to your router.
PostPosted: Thu Jan 13, 2005 10:43 am
ok when you say remove them from the mac and place them in the router i would do that by tapping into the router's firmware correct.
PostPosted: Thu Jan 13, 2005 1:00 pm
Yes
