It is currently Sun Feb 01, 2015 8:49 am
 Post subject: help
PostPosted: Mon Jan 10, 2005 4:52 pm
can someone tell me if the SiS 900 Fast ethernet Adapter is a NIC?
and also what is the difference between a switch and a router? and what is the name of the cable i need to connect 2 computers together with a router or switch
 Post subject: Re: help
PostPosted: Mon Jan 10, 2005 5:04 pm
King of All Voodoo2 Cards
Sure sounds like one, especially if it's got "Fast Ethernet Adapter" in the name.
A Switch will intelligently route packets between computers on a local area network.
A Router is a device that can automatically assign IPs to computers on the local area network via DHCP, share an internet connection between them using NAT, and keep pests out of the network.
An Ethernet Crossover Cable
PostPosted: Mon Jan 10, 2005 5:17 pm
i want to play LAN with my bro and also maybe surf the net with my 2 computers with a dial up service so which ione should i get a router or switch?
PostPosted: Mon Jan 10, 2005 5:22 pm
Buy a switch, then enable ICS between the two machines
